AK3200 ARUBA controller
  • 1.  AK3200 ARUBA controller
    Posted Dec 04, 2013 08:50 PM
    I am a new user for AK3200 aruba controller current in used. The controller was setup by earlier adminstrator, now i faced problem with remote AP configs, kindly show me how to view userid and pwd in my controller. thanks.
  • 2.  RE: AK3200 ARUBA controller
    Posted Dec 04, 2013 08:53 PM
    If you need to recover the admin username and password, you will need a console cable and follow instructions here:  https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/How-do-I-reset-the-enable-password-on-controller-and-set-a-new-password
  • 3.  RE: AK3200 ARUBA controller
    Posted Dec 04, 2013 11:20 PM
    not admin pwd, to reset the remote AP ! thanks
  • 4.  RE: AK3200 ARUBA controller
    Posted Dec 05, 2013 04:07 AM
    Which model of Remote AP is it?
  • 5.  RE: AK3200 ARUBA controller
    Posted Dec 05, 2013 10:57 PM
    AP 125 AND 105
  • 6.  RE: AK3200 ARUBA controller
    Posted Dec 06, 2013 12:10 AM
    You would do a purge, like this knowledgebase article describes here:  https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-160
  • 7.  RE: AK3200 ARUBA controller
    Posted Dec 06, 2013 02:58 AM
    thanks i will try that later, as the AP is remote site. BTW, do you have manual or guides on how to use or configure controller? thanks.
  • 8.  RE: AK3200 ARUBA controller
  • 9.  RE: AK3200 ARUBA controller
    Posted Dec 04, 2013 08:54 PM
    To reset the password, you will need to console into the controller and enter the following:
    User: password
    Password: forgetme!
    Then go in and reset the password:
    (controller)# config t
    (controller)(config)# mgmt-user admin root
    Password: <new password>
    Re-Type Password: <new password>
    (controller)# write mem
