Alaris Infusion pumps not connecting when High Throughput is enabled
  • 1.  Alaris Infusion pumps not connecting when High Throughput is enabled
    Posted Nov 19, 2018 10:52 AM
    Using 6.4.4.18 and AP-105's.  Alaris Infusion pumps state that they support 802.11 a/b/g/n.  We see that the pumps attempt to connect at a-HT or g-HT and always fail.  Removing HT from the SSID and the pumps connect.  A recommendation from the manufacturer (Care Fusion), to enable single chain legacy, which does not seem to be supported any longer.  Any thoughts?
  • 2.  RE: Alaris Infusion pumps not connecting when High Throughput is enabled
    Posted Nov 19, 2018 01:49 PM
    In ArubaOS 6.2 and above, "single-chain-legacy" was renamed to "diversity-spreading-workaround"
