Alcatel access points license upgrade and virtual controller
  • 1.  Alcatel access points license upgrade and virtual controller
    Posted May 17, 2015 03:38 AM
    we have a  customer having 8 X OAW-AP93 with Virtual controller solution from alcatel. they are looking to add another 6 X AP205H on the network. I have below clarifications .
    1. Can I add the aruba AP205H to this network ?
    2. can I add the aruba AP license to the virtual controller.
    3. If I propose them them a new aruba controller can  OAW-AP93 work with the aruba controller.
    4. What are the ethernet port available in the AP205H ?
  • 2.  RE: Alcatel access points license upgrade and virtual controller
    Posted May 17, 2015 09:13 AM
    as for 1,2 and 3 you can't mix Aruba and OEM equipment.
    4 i don't get, have a look at the data sheet i would say.
  • 3.  RE: Alcatel access points license upgrade and virtual controller
    Posted May 20, 2015 05:51 AM
    Not sure about the virtual side of things but we run Aruba APs on our Alcatel physical controllers without an issue.
  • 4.  RE: Alcatel access points license upgrade and virtual controller
    Posted May 20, 2015 07:36 AM
    sportmonkey,
    It is physically possible, but when it comes time to get support there will be issues.
  • 5.  RE: Alcatel access points license upgrade and virtual controller
    Posted May 20, 2015 08:01 AM
    We made sure that before we went ahead with this that our current support provider would cover us, the ensured that wouldnt be a problem . After a year of running with these(touch wood)be no problems what so ever.
    It is a good point to make tho! :)
