CLE and ALE have different interfaces (Websocket vs MQTT) and are not backward compatible as far as I know.
You will need to change your application to receive and interpret the CLE Location Feed.
Check here for the documentation around the Streaming API (Location/CLE).
Original Message:
Sent: Jan 05, 2023 10:31 AM
Subject: ALE to CLE migration
Hi
I have an application which uses ALE's streaming API to ingest Location events. I want to upgrade this to use CLE, does anyone know what is involved in the process or is it backwards compatible?
