Alert message when performing social logins
  • 1.  Alert message when performing social logins
    Posted Oct 09, 2014 06:53 AM
    Well, getting there with porting my dev config to the production server. I can now auth using my facebook account. However, on the production box I'm seeing an alert when I authenticate
    Session failed for Host=http://localhost:6600/battery, Reason=[get::<easy_perform>, (error=7) Couldn't connect to server]
    Rgds
    Alex
  • 2.  RE: Alert message when performing social logins
    Posted Oct 09, 2014 10:57 AM
    Usually when that is happens its an issue from guest talking to CPPM. The most common reason I have seen it happen is if you didnt deploy a VM with enough resources. I would suggest a reboot and if it continues can TAC.
  • 3.  RE: Alert message when performing social logins
    Posted Oct 09, 2014 11:50 AM
    This is our master clearpass server in a cluster. Not in use at the moment, but if I'm rebooting the master server, are there any things I need to do first or in a particular order?
    A
  • 4.  RE: Alert message when performing social logins
    Posted Oct 09, 2014 11:53 AM
    If it is the pub then you will not be able to create new guests or onboard until it is up.
    Just make sure if you have a backup pub that the time is set long enough that it wont roll over during the reboot cycle.
  • 5.  RE: Alert message when performing social logins
    Posted Oct 10, 2014 10:31 AM
    Well rebooted it but seems to have made no difference. :-((, still getting the same error message
  • 6.  RE: Alert message when performing social logins
    Posted Oct 11, 2014 12:37 AM
    Please open a TAC case
  • 7.  RE: Alert message when performing social logins
    Posted Aug 25, 2017 12:28 PM
    Hi there,
    I am working on an implementation of Clearpass (500 endpoints) and I am receiving a similar error message on the activity log:
    Session failed for Host=http://localhost:6600/battery, Reason=[get::<easy_perform>, (error=28) Timeout was reached]
    Should I consider the same error origin since the host of the VM has a deficit of two CPUs?
  • 8.  RE: Alert message when performing social logins
    Posted Aug 25, 2017 12:30 PM
    You should open a TAC case.
  • 9.  RE: Alert message when performing social logins
    Posted Aug 25, 2017 03:03 PM
    Thank you for the confirmation Capalli.
  • 10.  RE: Alert message when performing social logins
    Posted Nov 03, 2017 08:28 AM
    Jose
    Did you fix the isse with TAC?  If so, can you share the root casue? I am having the same issue. Posture enforcement is not working and the alert in access tracker is as below
    Sagi
    Policy server Session failed for Host=http://localhost:6600/battery, Reason=[get::<easy_perform>, (error=7) Couldn't connect to server].
  • 11.  RE: Alert message when performing social logins
    Posted Nov 12, 2019 01:59 PM
    Having the same issue too. Anyone have any updates on a fix?
    Not sure if it's related, but i am getting Online Status: Not Available in Access Tracker Summary log. I do have the accounting tab showing up with correct accounting information..
