When NAE (Network Analytics Engine) agents are deployed on 8320/8400 switch, these agents configuration are included in the show running configuration which can be a bit cumbersome to read.
You can skip the NAE part by using this command:
8320# show running-config | exclude nae
To simplify further on, you may use alias for this command.
Example of new showrun command without NAE information.
8320(config)# alias showrun show running-config | exclude nae
8320(config)# showrun
Current configuration:
!Version ArubaOS-CX TL.10.01.0001
hostname 8320
