Aliases definition
  • 1.  Aliases definition
    Posted Jul 01, 2017 08:25 AM
    Hi all,
    I am a bit confused with alias definition.
    If i have a firewall policy: any any svc-icmp permit
    Who is the alias?
    - network source
    - network destination
    - network service
  • 2.  RE: Aliases definition
    Posted Jul 01, 2017 08:30 AM
    An alias typically refers to a variable that represents an ip address or network:
    http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Firewall_Roles/Policies.htm
    In your example, the alias would be "any" because it would represent any network traffic.
  • 3.  RE: Aliases definition
    MVP EXPERT
    Posted Jul 01, 2017 08:33 AM
    Hi, there is a couple of Aliases. A network service alias :
    A network service alias defines a TCP, UDP or IP protocol and a list or range of ports supported by that service. When you create a network service alias, you can use that alias when specifying the network service for multiple session ACLs.
    (host)(config) #netservice <name> <protocol>|tcp|udp {list <port>,<port>}|{<port> [<port>]} [ALG <service>
    Or a Network Alias which can be either your source or destination subnet. So this is a network IP or IP ranges.
    (host)(config) #netdestination “Internal Network”
    network 10.0.0.0 255.0.0.0 network 172.16.0.0 255.255.0.0
  • 4.  RE: Aliases definition
    Posted Jul 03, 2017 03:35 AM
    Thank you guys. This question was in an exam and it was with alternatives.
    Only one answer should be chosen,..so Im confused:
    A. Net service
    B. Net source
    C. Net destination
  • 5.  RE: Aliases definition
    Posted Feb 22, 2019 04:28 AM
    A. Net service
    B. Net source
    C. Net destination
    The Answer is A. Should I say A is the more complete answer.
