Network Management
Allow Device on Diffrent Vlans to Router
  • 1.  Allow Device on Diffrent Vlans to Router
    Posted May 04, 2021 12:13 PM
    Hi
    Im new in Aruba in general and the Community and would like to know about the below issue I have.
    - I already post this but I can't return to it, seems I did a mistake on posting so I did it a gain
    I have a PC connected to Switch (A) 1930 untaged with Vlan 3
    This Switch (A) and similar 3 Switches (C,D,E) connected to Hub Switch(X) 2530 on Tagged Vlans 2,3,16,5,2,..
    A, B, C, and D switches connect to Switch(X) on Vlan 5.
    The issue is:
    1- I can't reach the router ip 192.168.1.1 on Vlan 16 from the PC on Vlan 3. until I can reach 192.168.50
    on SW(A) I already set default route to be 0.0.0.0 0.0.0.0 to 10.5.0.1
    on SW (X) default gateway is 192.168.1.1..But Sure I cant make a static route
    I also set ip for vlan 16 on SW (A) but the VLAN still down.
    So, I don't know where is the issue as I need PC 10.3.0.2  t0 reach 192.168.1.1
    Model
    <google-sheets-html-origin>
    Aruba 2530-24G Switch (J9776A)
    Aruba1930-48G Switch (JL686A)
    </google-sheets-html-origin>
    SW(A)
    MR Network
  • 2.  RE: Allow Device on Diffrent Vlans to Router
    MVP GURU
    Posted May 04, 2021 09:47 PM
    Do you have routes for both directions to 192.168.1.1, and back to 10.3.0.4 ?
    VLAN 16 shows as down, can you check to see if VLAN 16 is tagged on both sides of SwitchA and SwitchX.
    Dustin Burns
