last person joined: 3 hours ago
Allow Guest access for certain time
  • 1.  Allow Guest access for certain time
    Posted Nov 09, 2016 07:42 AM
    I configured an Open Guest SSID in Cloud Central and configured a Time Range Profile for the SSID to be broadcasted from 8AM until 8PM, but I couldn't find an option to allow the user only to be connected for a certain time (e.g. 1 hour). All I could find was an inactivity timeout which is defaulted at 1000 seconds.
    How can I make sure the user is automatically disconnected after an hour and has to login again?
  • 2.  RE: Allow Guest access for certain time
    Posted Nov 14, 2016 11:08 AM
