allow only workstations on SSID
  • 1.  allow only workstations on SSID
    Posted Aug 27, 2015 04:49 AM
    Hi everyone.
    Is it possible to allow only workstation connections (Windows7, MacOS etc) to SSID?
    I don't want to allow mobile devices (iphones, ipads etc) to connect to my enterprise network.
    How can I do it?
  • 2.  RE: allow only workstations on SSID
    Posted Aug 27, 2015 05:20 AM
    Hi ilmik,
    with IAP you have to use ClearPass for this filter.
    Massimo
    [If you found my post helpful, please give kudos]
  • 3.  RE: allow only workstations on SSID
    Posted Aug 27, 2015 06:22 AM
    HI,
    It all depends on policy mapped to the user role. we have to finger print the Mobile devices and deny access. it is very easy to achieve this with the help of CPPM.
    Please feel free for any further help on this.
