Comware
Alternatve to FlexFabric 5700 stackable switch with 10 Gb SPF+
  • 1.  Alternatve to FlexFabric 5700 stackable switch with 10 Gb SPF+
    Posted Oct 11, 2017 11:09 PM
    Do you know an alternatve to FlexFabric 5700 stackable switch at other brand ?
    This is only for comparison with equivalent products, with similar prices.
    I have reviewed the information available on the internet and so far I have not found an equivalent switch that has several network ports of 10Gb copper and fiber at a time.
    Plase provide any advice according your experience.
    Thanks.
     P.S:This thread has been moved from procurve to comware-Moderator.
    #stackable
    #5700
    #FlexFabric
  • 2.  RE: Alternatve to FlexFabric 5700 stackable switch with 10 Gb SPF+
    Posted Oct 12, 2017 12:44 AM
    Are you specifically referring to HPE FlexFabric 5700-32XGT-8XG-2QSFP+ Switch (JG898A) model?
  • 3.  RE: Alternatve to FlexFabric 5700 stackable switch with 10 Gb SPF+
    Posted Oct 12, 2017 11:32 AM
    Yes
  • 4.  RE: Alternatve to FlexFabric 5700 stackable switch with 10 Gb SPF+
    Posted Oct 12, 2017 11:47 AM
    First, better to move this whole thread to Comware based section...since the HPE FlexFabric 5700 is Comware operating system based (not ProVision operating system based)...Networking forum moderator will probably do that...then are you looking for a like for like product to compare? if so it's difficult to find a Switch from other manufacturer with the exact same number (and type) of physical ports (or slots) not to speak about specific Comware related features like IRF:
    • 32 10GbE
    • 8 SFP+ 1GbE/10GbE
    • 2 QSFP+ 40GbE (40Gbe or 4x10GbE)
    Maybe Arista has similar Switch for a reasonable comparison.
