AM not disabling N mode AP
  • 1.  AM not disabling N mode AP
    Posted Jan 17, 2012 03:40 PM
    I've got an AP 105 that I've got configured as an AM.
    It seems to work great at keeping my B/G clients from connecting to a rouge AP but not my N clients.
    What might I be doing wrong?
  • 2.  RE: AM not disabling N mode AP
    Posted Jan 17, 2012 03:47 PM
    I'm not sure this matters, but is High throughput enabled on both 2.4 and 5 in the radio profiles for your AM?
  • 3.  RE: AM not disabling N mode AP
    Posted Jan 18, 2012 01:00 PM
    Perhaps my post was premature...
    It does seem to be working, but it's not as quick to kill machines that have an existing connection to the rouge on N. B/G detection/protecting seemed to knock down connections to rogue APs almost instantally.
  • 4.  RE: AM not disabling N mode AP
    Posted Jan 18, 2012 02:19 PM
    mcolwell,
    Do you have the IDS/IPS (RF Protect License)?  If so, tarpitting is more effective than the standard deauth with the base license.
  • 5.  RE: AM not disabling N mode AP
    Posted Jan 20, 2012 05:27 PM
    @cjoseph wrote:
    mcolwell,
    I'm licensed for WIP, PEF, Next Gen PEF
  • 6.  RE: AM not disabling N mode AP
    Posted Jan 20, 2012 06:12 PM
    @mcolwell wrote:
    @cjoseph wrote:
    mcolwell,
    Okay.  First check to see what kind of wireless containment you are doing:
    (orion.arubanetworks.com) (IDS General Profile "default") #show ids general-profile default
    Parameter Value
    Stats Update Interval 60 sec
    Monitored Device Stats Update Interval 0 sec
    AP Inactivity Timeout 20 sec
    Adhoc (IBSS) AP Inactivity Timeout 5 sec
    AP Max Unseen Timeout 600 sec
    Adhoc AP Max Unseen Timeout 180 sec
    STA Inactivity Timeout 60 sec
    STA Max Unseen Timeout 600 sec
    Min Potential AP Beacon Rate 25 %
    Min Potential AP Monitor Time 2 sec
    Signature Quiet Time 900 sec
    Wireless Containment deauth-only  <----------------
    Debug Wireless Containment false
    Wired Containment false
    Wired Containment of AP's Adj MACs false
    Mobility Manager RTLS false
    IDS Event Generation on AP none
    Send Adhoc Info to Controller true
    You can change that to tarpit, instead:
    (3600.arubanetworks.com) (config) #ids general-profile default
    (3600.arubanetworks.com) (IDS General Profile "default") #wireless-containment tarpit-all-sta
    Check to make sure you changed it:
    (3600.arubanetworks.com) (config) #show ids general-profile default
    Parameter                               Value
    Wireless Containment                    tarpit-all-sta  <-----------
     Now the AP should use tarpitting, instead of deauths.
  • 7.  RE: AM not disabling N mode AP
    Posted Jan 23, 2012 11:54 AM
    I don't seem to have those options.
    It looks like you need RFProtect for tarpit options??
    If you can do this without RFProtect, what's the minimum OS you need?
  • 8.  RE: AM not disabling N mode AP
    Posted Jan 23, 2012 12:09 PM
    When you upgrade to AOS 6.x, the WIP license will automatically be upgraded to the RFProtect license.  You are currently licensed for WIP which means you will be licensed for RFProtect once you upgrade.  AOS 6.0 introduced a lot of new IDS features including tarpitting, a new configuration wizard, new IDS signatures, better channel scanning, etc.  I would recommend upgrading to AOS 6.1.2.7 if your controller supports it.  Legacy controllers (200, 800, 2400, sup1, sup2) do not support 6.x.  The current generation of controllers (6xx, 3xxx, M3) support AOS 6.x.
    Another option to consider is enabling wired containment in addition to the wireless containment.  It will help keep the rogue device off of the network.
  • 9.  RE: AM not disabling N mode AP
    Posted Jan 23, 2012 03:34 PM
    I'm stuck on 5.x because about 1/2 of my controllers are too old.
    I'd considered pulling the old ones off my master controller and creating a second master/local system that contained just the non 6.x compatible equipment - but I don't know if it's worth the added admin time.
