amigopod as a secondary CPPM Guest auth source
  • 1.  amigopod as a secondary CPPM Guest auth source
    Posted Jan 26, 2015 06:31 PM
    How can I use amigopod 3.9 DB with 100k guest accounts as a secondary CPPM Guest authentication source on a new CPPM instalation. In a transition period I would like the Guest Authentication service to first authenticate against local DB (for new Guest accounts) with fall-back to existing amigopod guest accounts until department operators have created new bulk accounts.so I can shut down amigopod entirely.with It is important that I keep the disruption of the current amigopod RADIUS service to a minimum I am aware of the below tech note but need to clearly understand if there are any caveats in regards to accessing the existing guest accounts after changing/adding database configuration http://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/AAANACGuestAccessBYOD/article-id/128 /rene
