Amigopod authentication against separate database
  • 1.  Amigopod authentication against separate database
    Posted May 15, 2012 05:55 AM
    Has anybody managed to set-up an Amigopod appliance to authenticate guest users against a database residing on a different server?
    I need to be able to configure an Amigopod appliance to create guest accounts (via a self-registration page) on to a totally separate Amigopod appliance. The reason being the 2 appliances are located in different areas of the network with restricted access for end users.
    From looking through the Database list section it appears you can add another database on a remote server and make this active but has anybody done this and are there any pitfalls??
    David
  • 2.  RE: Amigopod authentication against separate database
    Posted May 15, 2012 04:29 PM
    3.9 added the ability to point one Amigopod to another for READ ONLY access.  Checkout Administrator > System Control > Database Config for the option to " You would then go to RADIUS > Database List on the other Amigopod and setup a connection pointing to this one.
