Amigopod - having trouble editing guest account passwords
  • 1.  Amigopod - having trouble editing guest account passwords
    Posted May 30, 2012 03:29 PM
    Aruba ClearPass Guest OS release 3.9 -
    I create a non-expiring guest account and want to edit the account and change the password and change the session limit to 0.  I want a manually created password not random.  I type in the password and change the session limit and get
    Passwords do not match
  • 2.  RE: Amigopod - having trouble editing guest account passwords
    Posted May 30, 2012 03:51 PM
    Did you type the password twice?
  • 3.  RE: Amigopod - having trouble editing guest account passwords
    yes
  • 4.  RE: Amigopod - having trouble editing guest account passwords
    Posted May 30, 2012 03:57 PM
    Please open a support case.  Every time I have put in the same password twice, it has worked, along with changing the simultaneous sessions on 3.9 for a guest user.
  • 5.  RE: Amigopod - having trouble editing guest account passwords
    Posted May 30, 2012 04:00 PM
    will do, getting the password do not match message under the random section, not the original password section.  If that makes any sense
    * Password:Type in a new password Select an option for changing visitor account passwords.New password:Confirm Password:Password:
     (No changes)Create new random passwords
    Type in a new password to assign to the visitor accounts.
    Repeat the new password for the visitor account.
    gwfcpivK
    This is the new password that will be assigned to this visitor account.
  • 6.  RE: Amigopod - having trouble editing guest account passwords
    Posted May 30, 2012 04:03 PM
    Hold on.
    Did you want to create a random password or not?  Are you doing it for a single user or multiple users?
  • 7.  RE: Amigopod - having trouble editing guest account passwords
    single user, not a random password.  Want to type in manually.
  • 8.  RE: Amigopod - having trouble editing guest account passwords
    Posted May 30, 2012 04:07 PM
    How are you selecting an existing user?  What menu did you use?  I used both Guest> Edit Accounts and Guests> List Accounts> Edit and it is working for me so far.
    What is your workflow?
  • 9.  RE: Amigopod - having trouble editing guest account passwords
    Posted May 30, 2012 04:11 PM
    I tried both ways. (Guests>List Accounts> click on the account>edit>password>type in a password)
    also (Guests>Edit Accounts>click on the account>edit>Password>Type in a new password)
    both fail with same message
  • 10.  RE: Amigopod - having trouble editing guest account passwords
    Posted May 30, 2012 04:12 PM
    Please open a case with support.
  • 11.  RE: Amigopod - having trouble editing guest account passwords
    Posted May 30, 2012 04:14 PM
    I think i have the random password section in there and it has to be removed.  I will open a case
  • 12.  RE: Amigopod - having trouble editing guest account passwords
    Posted Jun 11, 2012 05:23 PM
    it was a hidden field applied to that form.  Removed it and all is well now, thanks!
