Amigopod onboard
  • 1.  Amigopod onboard
    Posted Jan 17, 2013 03:02 PM
    I have problem,
    we created selfsigned portal so user can create temporary user for one hour, so the user can onboard his device.
    this works fine but. The problem is that onboard looks at the expire time, and create a onboard user for one hour, is there a way to change this for example one year? This is for the peap variant the tls devices works fine.
  • 2.  RE: Amigopod onboard
    Posted Jan 17, 2013 04:20 PM
    You didn't specify your version, so I assume you are using 3.9.
    Configure Onboard to perform a RADIUS authorization when the device is provisioned.  Then, return a Session-Timeout value of the desired length.  This should take priority over the short lifetime of the user account and solve the issue.
  • 3.  RE: Amigopod onboard
    Posted Jan 18, 2013 04:43 PM
    I going it to test it in the lab.
    Thanks for your advice.
  • 4.  RE: Amigopod onboard
    Posted Feb 27, 2013 04:16 AM
    I have tested your solution and it is not working as you said.
    It still use the experation time from the temp user.
