Amigopod to clearpass license upgrade
  • 1.  Amigopod to clearpass license upgrade
    Posted Mar 17, 2015 08:29 PM
    I have a question regarding upgrading Amigopod to Clearpass with regards to licensing.
    We currently have the following:
    Amigopod AMG-SW-50 + AMG-LIC-100 + Onboard 2500
    2x CP-VA-5K
    I understand that Guest licenses transfer 1 to 5, onboard 1 to 1.  Hence when we upgrade we should get (750 guest ((50+100)x5) + Onboard 2500.  However, am I correct to assume that we would also get another CP-VA-5K?  If so would this include the corresponding 5K Clearpass PM licenses?
    Thanks in advance...
  • 2.  RE: Amigopod to clearpass license upgrade
    Posted Mar 17, 2015 10:06 PM
    When you migrate you amigopod VM you will get another CPPM VM and in your case this wil be a VA-5K.
    Not sure what you eman when you refer to the PM licenses..... the 5K will have
    5K - AAA
    750 - Guest
    2.5K - OnBoard
    This node could then also be clustered with the other two nodes and the Guest + OnBoard shared across the threee nodes in the cluster.
