AMON MMVA and AirwaVe
  • 1.  AMON MMVA and AirwaVe
    Posted Jun 27, 2019 03:43 AM
    We are configuring AMON to AMP with ip 192.168.16.62
    Is this all the config necessary - we do not need DTLS encr.
    #show running-config | include mgmt-server
    Building Configuration...
    mgmt-server primary-server 192.168.16.62 profile default-amp transport udp
    mgmt-server profile "default-acp"
    mgmt-server profile "default-ale"
    mgmt-server profile "default-amp"
    mgmt-server profile "default-controller"
    mgmt-server profile "default-niara"
    #show mgmt-server message-counters process ctamon
    Mgmt Config profile "default-amp" (Predefined (changed))
    Parameter                           Value
    Stats                               Enabled
    Stats_Ext                           Disabled
    Generic_amon                        Enabled
    Tag                                 Enabled
    Sessions                            Enabled
    Monitored Info - Add/Update         Disabled
    Monitored Info - Deletion           Disabled
    Monitored Info - Periodic Snapshot  Disabled
    User_visibility                     Enabled
    Wireless IDS Event Info             Enabled
    Misc                                Enabled
    Location                            Enabled
    UCC Monitoring                      Disabled
    AirGroup Info                       Disabled
    Inline DHCP stats                   Enabled
    Inline AP stats                     Enabled
    Inline Auth stats                   Enabled
    Inline DNS stats                    Enabled
    Is  this the command to view among messages sent by MM to AirWave?
    If there is something wrong, please point the right document.
    (ArubaMM-VA) [mynode] (config) #show mgmt-server message-counters process ctamon
    Message Counter History
    Message Number Time Packets
    WAN State Info                      Disabled
    Inline LLDP stats                   Disabled
    AP stats                            Disabled
    BR,
  • 2.  RE: AMON MMVA and AirwaVe
    Posted Jun 27, 2019 04:08 AM
    Additional info:
    (CNSYS-WLC-1) [MDC] *#show mgmt-server message-counters process vrrp
    Message Number Time Packets VRRP Master Redundancy Info
    3496 Thu Jun 27 10:45:59 2019 1 1
    3495 Thu Jun 27 09:45:53 2019 1 1
    3494 Thu Jun 27 08:45:48 2019 1 1
    3493 Thu Jun 27 07:45:42 2019 1 1
    3492 Thu Jun 27 06:45:37 2019 1 1
    3491 Thu Jun 27 05:45:32 2019 1 1
    3490 Thu Jun 27 04:45:26 2019 1 1
    3489 Thu Jun 27 03:45:21 2019 1 1
    3488 Thu Jun 27 02:45:15 2019 1 1
    3487 Thu Jun 27 01:45:10 2019 1 1
    3486 Thu Jun 27 00:45:04 2019 1 1
    3485 Wed Jun 26 23:44:59 2019 1 1
    3484 Wed Jun 26 22:44:53 2019 1 1
    3483 Wed Jun 26 21:44:48 2019 1 1
    3482 Wed Jun 26 20:44:43 2019 1 1
    3481 Wed Jun 26 19:44:37 2019 1 1
    3480 Wed Jun 26 18:44:32 2019 1 1
    3479 Wed Jun 26 17:44:26 2019 1 1
    3478 Wed Jun 26 16:44:21 2019 1 1
    3477 Wed Jun 26 15:44:15 2019 1 1
    (CNSYS-WLC-1) [MDC] *#show mgmt-server message-counters process ctamon
  • 3.  RE: AMON MMVA and AirwaVe
    MVP EXPERT
    Posted Jun 27, 2019 04:46 AM
    Have you enabled Prefer AMON over SNMP within AirWave configuration? You can view if AirWave is processing AMON information via the System -> Peformance page.
  • 4.  RE: AMON MMVA and AirwaVe
    MVP EXPERT
    * double post ;) *
  • 5.  RE: AMON MMVA and AirwaVe
    Posted Jun 27, 2019 05:03 AM
    Thanks for the fast response.
    When I click prefer amon button the devices fall from 150 to 18.
    Lots of devices are not speaking amon - this should prefer amon, but will use snmp still ?
    Here are the two snips attached
  • 6.  RE: AMON MMVA and AirwaVe
    MVP EXPERT
    Posted Jun 27, 2019 05:06 AM
    Do the devices matchup with what you see on your controller? What AOS &
    AirWave versions are you running? Don't forget it will take (depending on
    the poll time you have configured...) a while for AirWave to poll the
    devices.
  • 7.  RE: AMON MMVA and AirwaVe
    Posted Jun 27, 2019 07:08 AM
    AMP =  8.2.8.2
    MM/2 7010 = 8.4.0.0_68230
    When prefer AMON is enabled we experience the following issues(attached)
    CLient count fluctuates up and down. In the and you can see it stabilized as I turned SNMP only. 13:45
  • 8.  RE: AMON MMVA and AirwaVe
    Posted Jun 27, 2019 09:00 AM
    in Airwave, you should be able to go to System> Performance> Amon Statistics to see if you have any AMON coming in.  You should leave Prefer Amon OFF for now.
  • 9.  RE: AMON MMVA and AirwaVe
    Posted Jun 27, 2019 09:12 AM
    The requested info is attached.
    Not sure if this correct? the count is very low?
    Prefer AMON is OFF**
  • 10.  RE: AMON MMVA and AirwaVe
    Posted Jul 01, 2019 10:35 AM
    Solved.
    With UPG to AMP 8.2.9.0
