AMON Profile on Controller for IntroSpect
  • 1.  AMON Profile on Controller for IntroSpect
    Posted Jul 18, 2018 09:44 PM
    I was looking at configuring AMON connection to IntroSpect from my Aruba Controller.  I have a few questions
    1. Is there a recomended AMON Profile setting ?  What knobs should we enable?
    2. What is the correct Management Server type - I have AOS 6.5 which has AMP, ALE, and Central?
    3. What is the Minimum AOS code level on the controller that supports AMON to IntroSpect?
  • 2.  RE: AMON Profile on Controller for IntroSpect
    Posted Jul 18, 2018 10:21 PM
    Kelly,
    You should reach out to you local Security CSE. If you not sure who it is send me a direct message with your contact info and Ill find out for you.
  • 3.  RE: AMON Profile on Controller for IntroSpect
    Posted Jul 19, 2018 11:17 PM
    Hi Kelly,
    There is no pre-defined profile for IntroSpect yet.  So you would need to set on up. The only AMON feed you need are FW sessions and DNS stats:
    config t
    mgmt-server profile introspect
      sessions-enable
      inline-dns-stats
      no inline-ap-stats
      no inline-auth-stats
      no inline-dhcp-stats
    mgmt-server type amp primary-server <PP_IP>  profile introspect
    A default introspect profile will be added in AOS in the future.
    All recent (within last couple of years) of AOS should support this.  The AMON feed has not changed much.
