Network Management
AMOP 8.2.7: Restore with Nightly backup?
  • 1.  AMOP 8.2.7: Restore with Nightly backup?
    Posted Nov 22, 2018 10:44 AM
    I know we can download nightly backup now via Webgui in 8.2.7.. but how can we restore AMP with a downloaden nightly backup?
    I think using Webgui as well, but can not find it.
  • 2.  RE: AMOP 8.2.7: Restore with Nightly backup?
    Posted Nov 22, 2018 11:28 AM
    We need to upload the backup file  using scp option and execute restore from AMPCLI command list.
    If you are not able to upload the file then you need to take the help of TAC they will assist in upload the backup to the server.
  • 3.  RE: AMOP 8.2.7: Restore with Nightly backup?
    Posted Nov 23, 2018 02:59 AM
    Alright, that makes sense, but I know SCP is unavailable - correct by default? Or is there a manual how to set it up in 8.2.7?
  • 4.  RE: AMOP 8.2.7: Restore with Nightly backup?
    Posted Nov 23, 2018 05:25 AM
    AirWave Management Platform 8.2.7 on localhost.localdomain
      1  Upload File
      2  Download File
      3  Delete File
      4  Backup
      5  Restore
      6  Support
      7  Upgrade
      8  Advanced
      9  Security
    10  Custom Commands
      q  >> Quit
    Your choice: 1
    Running Upload File
    SCP Source (user@host:path): root@10.17.164.XX:/tmp/AMP-8.2.7-X86.64.cvs.tar.gz
    Password:
    Uploading root@10.17.164.XX:/tmp/AMP-8.2.7-X86.64.cvs.tar.gz
        100%   10KB  10.0KB/s   00:00
    You need exteranl server to upload file.
