Network Management
AMP 2nd network Device settings not being saved
  • 1.  AMP 2nd network Device settings not being saved
    Posted Nov 03, 2016 11:48 AM
    I am installing AMP 8.2.2 for a customer and he would like to add the 2nd Network device and the NTP servers.  Under AMP Setup \ Network - I enable the 2nd NIC capability enter in the IP information, then enter in the NTP information, hit save and the informatin is not saved.
    Any suggestions?
  • 2.  RE: AMP 2nd network Device settings not being saved
    Posted Nov 03, 2016 12:18 PM
    Why are you using a second NIC?
  • 3.  RE: AMP 2nd network Device settings not being saved
    Posted Nov 04, 2016 12:06 PM
    The end user has one network for internal access (primary network device) and another network for remote access (secondary device).  and while I have you is the name entered for DNS case sensitive?
