Network Management
AMP does not show how many APs are UP or DOWN - since 8.2.x
  • 1.  AMP does not show how many APs are UP or DOWN - since 8.2.x
    Posted Feb 01, 2017 03:13 PM
    Since we have upgraded to 8.2.x - now we run 8.2.3 - it never showed # of APs UP or DOWN
    See screenshot attached. Is tere a way to fix this quickly?
  • 2.  RE: AMP does not show how many APs are UP or DOWN - since 8.2.x
    Posted Feb 01, 2017 03:39 PM
    Can you please check the system > performance? To make sure your system resources look good
    Get Outlook for iOS
  • 3.  RE: AMP does not show how many APs are UP or DOWN - since 8.2.x
    Posted Feb 02, 2017 03:11 AM
    In my opinion everysthing seems pretty smooth, no process issues..
    See screenshots attached
  • 4.  RE: AMP does not show how many APs are UP or DOWN - since 8.2.x
    Posted Feb 02, 2017 05:56 AM
    Is this just the top header in Airwave, or are the APs showing Up also in Folder view or Group view when they are actually down?
  • 5.  RE: AMP does not show how many APs are UP or DOWN - since 8.2.x
    Posted Feb 02, 2017 06:17 AM
    Yes just in the Top Header #'s are not shown.
    When going to Groups, I see all the Groups, with it's AP's in it..
    As well in the folder view see screenshot.
  • 6.  RE: AMP does not show how many APs are UP or DOWN - since 8.2.x
    Posted Feb 02, 2017 06:52 AM
    Did you try to go to amp setup > top header and remove and add the devices up?
  • 7.  RE: AMP does not show how many APs are UP or DOWN - since 8.2.x
    Posted Feb 02, 2017 07:21 AM
    Yes I tried > rebooted the AMP server as well.. no luck.
    See screenshot about UP devices in APs/Devices - shows the 94 devices..
