AMP high Process use
  • 1.  AMP high Process use
    Posted Sep 22, 2014 04:09 PM
    My AMP is starting to use more swap memory.  When I run TOP in the cli I see below:  What is yes?
    21594 root      20   0 98.5m  524  488 R 100.0  0.0  48287:12 yes
    15151 root      20   0  117m 1996  572 R 54.3  0.0  25630:02 screen
      112 root      20   0     0    0    0 S 11.3  0.0 444:32.47 events/13
      100 root      20   0     0    0    0 S  5.3  0.0 974:57.85 events/1
    21632 root      20   0 1595m 440m 2220 S  5.3  0.7   3431:46 httpd__________
      108 root      20   0     0    0    0 S  5.0  0.0   1102:12 events/9
    17502 root      20   0 2194m 687m 263m S  5.0  1.1   4:48.74 httpd__________
    17479 root      20   0 2265m 762m 263m S  4.6  1.2   4:45.76 httpd__________
    17511 root      20   0 2201m 695m 263m S  4.6  1.1   4:49.64 httpd_______
  • 2.  RE: AMP high Process use
    Posted Sep 22, 2014 04:37 PM
    There's no process called 'yes'.  Do you have any 3rd party packages installed?  Is there a yes.log in /var/log?  Sounds fishy and may warrant opening a support case to look into.
  • 3.  RE: AMP high Process use
    Posted Sep 24, 2014 09:52 AM
    I did create a call to TAC and learned the following and I thought I should share:
    The process you mentioned “yes”, you need to kill the process. Someone might have executed the “yes” on the command line prompt. The yes command is used to output "y" forever.
    So, you can kill the process or reboot.
