  • 1.  AMP issue
    Posted Jan 31, 2013 02:19 PM
    My Airwave platform showed all APs down. This was not in fact true. I rebooted the server, now I cannot connect with a browser.
    Any help appreciated. Thanks.
  • 2.  RE: AMP issue
    Posted Jan 31, 2013 03:59 PM
    What version of AMP was your server running?  This may be the symptom of a larger issue.
    Check the server health:
    -disk space (is the / volume full?)
         # df -h
    -memory (is the server hitting swap?)
         # top -c
    -amp disabled? (if this file exists, it means AMP disabled itself)
         # ls /etc/amp_disabled
    Other files worth checking:
    /var/log/low_level_service_watcher
    /var/log/service_watcher
    /var/log/httpd/error_log
    If nothing obvious stands out, then please open a support case.  Support techs should be able to start a web meeting to diagnose the issue quickly.
  • 3.  RE: AMP issue
    Posted Feb 01, 2013 09:43 AM
    Thanks for the commands, very useful.
    The server came up yesterday afternoon.
    I can browse into my AMP application but the only device it sees up is the Standby Controller(VRRP Master/Standby).
    All my APs and the Master are down in AMP, but up and running in reality......bizarre...
  • 4.  RE: AMP issue
    Posted Feb 01, 2013 10:33 AM
    Does System -> Status show all daemons are up in 'green' state?  Or are any items in the 'red'?
    Also, what's System -> Performance showing?  Usage of swap?  High database I/O?
  • 5.  RE: AMP issue
    Posted Feb 01, 2013 10:49 AM
    I upgraded to 7.6.2.
    Now I can't get into the server from the browser....
    I ran cat low_level_service_watcher
    Fri Feb 1 10:39:05 2013: Started
    Fri Feb 1 10:39:05 2013: Couldn't find any apache processes; restarting.
    Stopping httpd: [FAILED]
    Starting httpd: [ OK ]
    Stopping Pound: [FAILED]
    ran amp_enable
    Fri Feb 1 10:44:20 2013: Couldn't find any apache processes; restarting.
  • 6.  RE: AMP issue
    Posted Feb 01, 2013 10:55 AM
    This isn't something we've been seeing in our lab during testing.  I've got time to take a look if you're available.  Sending you my contact info in a private message.  You'll be able to access the message by clicking on the envelope next to your name at the top of the Airheads page.
  • 7.  RE: AMP issue
    Posted Feb 04, 2013 10:57 AM
    Thanks for your help Rob!
    AMP restore of 7.5.5 on 7.6.2 code needed to run through database upgrade
    a.       This was accomplished by running # root; make
    b.      We saw the AMP come back online viewing # wd (alias for # watch daemons)
    SNMP string had been reconfigured without my knowledge.
