AMP templates and IAP blacklists
  • 1.  AMP templates and IAP blacklists
    Posted Feb 17, 2014 06:26 AM
              We have added several client mac addresses to an IAP blacklist that has created a mismatch on our AMP server  - is there a way to ammend the template so that it won't generate this mismatch? The AMP server is running 7.6.5 soon to be upgraded to 7.7.9.
    Many Thanks
    Mike
  • 2.  RE: AMP templates and IAP blacklists
    Posted Feb 17, 2014 07:31 AM
    You can navigate to the Aps/Devices -> Click on the wrench icon next to the VC.
    Scroll to the bottom and click on "Import settings".
    If that does not do it, then click on Audit, fetch and import the template again.
  • 3.  RE: AMP templates and IAP blacklists
    Posted Feb 17, 2014 07:52 AM
    Thanks for the reply - sadly neither method clears the mismatch on AMP. What I really want is the command(s) I can add to the template so that it won't audit any configuration regarding the blacklist. The estate is some 8000 sites and so getting this template right is rather crucial.
    Mike
  • 4.  RE: AMP templates and IAP blacklists
    Posted Feb 17, 2014 08:46 AM
    in the template, do the following
    blacklist-client de:ad:be:ef:ca:fe
    That should do it I think
  • 5.  RE: AMP templates and IAP blacklists
    Posted Mar 03, 2014 02:17 PM
    Sorry for the delay - no that didn't work either , has anyone used
    <ignore_and_do_not_push>blacklist</ignore_and_do_not_push>
    in the template and got it working?
    Regards
    Mike
