If for some reason you need to hide the link that shows the 'view device credentials' link on the manage page, here's a quick run through on how to accomplish this:
1. The before -> any device's manage page
2. Making the change
Login to AMP CLI
# dbc 'update seas_config set hide_secrets = 1;'
3. Refresh that manage page, it should now look like:
*Note - others can still blindly change the settings by accident, be careful who you give access to your AMP.
To reverse:
# dbc 'update seas_config set hide_secrets = 0;'
It's a good practice to do this if you have any users who disable the AMP GUI Idle Timeout. It's also suggested if you make use of AMP as a dashboard that is readily available when you walk in the door. If you have suggestions on how to improve this feature, please add it into the Idea Portal on support.arubanetworks.com.
