Network Management
AMP WHITELIST
  • 1.  AMP WHITELIST
    Posted Feb 20, 2018 10:56 AM
    Hi Guys!
    Yesterday I applied a change in whitelist now it does not allow me to enter even placing IP in the same segment. The ip is a prefix / 16. There is some IP exclusion in which you can enter and make the change.
    This is the message shown:
     IP address is not in the approved AMP whitelist. Please contact the AirWave administrator for assistance.
    Thanks everybody!
  • 2.  RE: AMP WHITELIST
    Posted Feb 20, 2018 11:38 AM
    As you mentioned that you have whitelisted one IP yesterday,can you remove that IP save it and then add both the IPs and check the status.
  • 3.  RE: AMP WHITELIST
    Posted Feb 20, 2018 11:44 AM
    Thanks Pavan
    I can't delete the ip because show me this message
    I need if exist other alternative ip for ingress the platform and do realize the change IP or disable whitelist
  • 4.  RE: AMP WHITELIST
    Posted Feb 20, 2018 01:24 PM
    Do you still have CLI access?  If so, then open a support case, and support can disable the whitelist from the CLI.  This will at least let you regain UI to lock it down again.
  • 5.  RE: AMP WHITELIST
    Posted Feb 20, 2018 03:42 PM
