Android Lollipop: Onboard - Additional DNS entry
  • 1.  Android Lollipop: Onboard - Additional DNS entry
    Posted Dec 14, 2014 06:59 PM
    I've been doing some testing with Lollipop and it appears that you will need to add an additional DNS entry to your Android netdestination in order for devices to be able to download QuickConnect from the Play Store.
    You'll need to add:
    *.l.googleusercontent.com
    netdestination ND-GOOGLEPLAY
      name android.clients.google.com
      name *.l.googleusercontent.com
  • 2.  RE: Android Lollipop: Onboard - Additional DNS entry
    Posted Dec 14, 2014 08:09 PM
    Why is *.ggpht.com not in there?
  • 3.  RE: Android Lollipop: Onboard - Additional DNS entry
    Posted Dec 14, 2014 08:10 PM
    I wanted to restrict it down to the least number of entries and it completed the process without the entry. I think that may be used for certain elements of the play store UI which are not used because you are going directly to the application.
  • 4.  RE: Android Lollipop: Onboard - Additional DNS entry
    Posted Dec 14, 2014 08:14 PM
    Thank you.
  • 5.  RE: Android Lollipop: Onboard - Additional DNS entry
    Posted Mar 12, 2015 09:01 PM
    Some new developments here. This is my current working setup:
      name *.gvt1.com
      name *.ggpht.com
    android.clients.google.com hosts some required elements of the Play store
    gvt1 hosts the actual application APK cache
    ggpht hosts the application images in play store
  • 6.  RE: Android Lollipop: Onboard - Additional DNS entry
    Posted May 16, 2018 02:20 PM
    Do you have any updated entries?
  • 7.  RE: Android Lollipop: Onboard - Additional DNS entry
