Android Q beta and chrome guest Capture portal issues
  • 1.  Android Q beta and chrome guest Capture portal issues
    Posted Aug 16, 2019 03:19 PM
    Hello
    We have a valid cert on our IAP. recently we were told about Chrome user unable to connect.
    I'm a beta tester for Android Q and i cannot get my phone to connect no matter what i try, even different browsers.
    my phone has connected before and connects fine to our employee network just fine (no CP)
    the cert is our own and alid for the next 3 months.
    anyideas what is casuing this? we are currently getting a new cert for this (as it is almost expired)
    Iphone connect just fine
    chrome throws and invalid cert error even though the cert is fine.
    it never give me the capture page to login.
  • 2.  RE: Android Q beta and chrome guest Capture portal issues
    Posted Aug 16, 2019 04:30 PM
    I am not sure that Aruba troubleshoots anything before the software becomes GA, because so many things can change.
  • 3.  RE: Android Q beta and chrome guest Capture portal issues
    Posted Aug 16, 2019 04:45 PM
    my phone is not the only one having issue chrome will not work at all and android phone have issues
  • 4.  RE: Android Q beta and chrome guest Capture portal issues
    Posted Aug 17, 2019 08:46 AM
    Understood.
    Your title made it seem the problem is with Android Q beta.
    What process did you use?
  • 5.  RE: Android Q beta and chrome guest Capture portal issues
    Posted Aug 19, 2019 03:35 PM
    I found the issue
    The Private DNS setting was messing with it! ugh stupid thing
    also it seem android devices have issues we certian CA and just think it is bad no matter what
