Another Patch Still Issues
  • 1.  Another Patch Still Issues
    Posted Jan 16, 2014 08:24 AM
    Is Airwave still bleeding edge or something?  Seems like there are constantly patches coming out yet there are still tons of issues.  Instant Config was working ok for me, upgrade to 7.7.8 and get this trying to login into my instant config page.
    IGC engine is not currently running. It may be disabled. Enable it on the Groups Basic page. The engine may take a few minutes to start after it is enabled.
    It is enabled and has been enabled, need to make changes, anyone know a quick fix for this?
  • 2.  RE: Another Patch Still Issues
    Posted Jan 16, 2014 09:11 AM
    MerrillTG,
    There is no way to tell what your issue is without opening a case. I can tell you that Airwave is NOT on the bleeding edge. Newer features like Instant config in any comprehensive product will have bugs as they evolve. If you open a case we can ensure that the changes necessary to make it work right will be made.
  • 3.  RE: Another Patch Still Issues
    Posted Jan 16, 2014 09:37 AM
    Also if you have a list of issues, if you post we may have answers for you
