Developer
Ansible add multiple ports to vlan
  • 1.  Ansible add multiple ports to vlan
    Posted Apr 30, 2020 08:14 AM
    The last couple of days i created a nice playbook for our switches to be configured out of the box. Everything is done via Ansible and works fine. The only thing i cant get to work is add ports a vlan via a loop.
    I want to have a list like: untagged_ports: [1/1, 1/2, 1/3].
    Than Ansible needs to do something like:
    port_id: "{{ item.data_vlan_ports}}"
            port_mode: "{{ item.mode}}"
          with_items:
            - {mode: POM_UNTAGGED, data_vlan_ports: "{{untagged_ports}}"}
    The following code gives me the error:
    HTTP Error 400: Bad Request", "requestid": "", "server": "eHTTP v2.0", "status": 400, "transfer-encoding": "chunked".
    what do i wrong?
    Can someone please point me in the right direction. I found many tutorials about lists and in a debug it works. Only in combination with aruba vlan it doesnt work.
    In the end i want to achieve something like this:
    vlan_1_ports:
    		[1, 2, 3, 7]
    	- untagged:
    		[10, 11, 12]
    vlan_2_ports:
    		[1,2]
    	- untagged:
    		[23, 24]
    Thanks in advance.
  • 2.  RE: Ansible add multiple ports to vlan
    Posted May 01, 2020 05:32 PM
    Hey jangenent!
    It looks like you're using the arubaoss_vlan module to do this, right?
    We actually have an example of how to achieve what you're looking for here:
    https://github.com/aruba/aruba-ansible-modules/blob/master/example_playbooks/arubaoss/vlan.yml
    On line 57, we're using a loop to remove multiple ports from a VLAN. What you're trying to do is essentially the same except this example is a subtractive operation as opposed to an additive operation. But hopefully this example gives you an idea of how to structure your loop!
    Cheers,
    Derek
