Developer
Ansible and output of arubainstant_config
  • 1.  Ansible and output of arubainstant_config
    Posted Apr 21, 2020 09:13 AM
    Hi
    is there a way to have a nicer output from Ansible if you do a "show network" on a IAP via REST API ? At the moment it looks like this.
    And you have to use the ugly "-v" extension on the command to get any output at all.
    ansible-playbook play.yml -i /etc/ansible/hosts -v
    Using /etc/ansible/ansible.cfg as config file
    PLAY [Show existing network] **********************************************************************************************************************************************************************************************************************************************
    TASK [Show existing network as a show command through API] ****************************************************************************************************************************************************************************************************************
    [WARNING]: Module did not set no_log for password
    [WARNING]: Platform linux on host 192.168.100.31 is using the discovered Python interpreter at /usr/bin/python, but future installation of another Python interpreter could change this. See
    https://docs.ansible.com/ansible/2.9/reference_appendices/interpreter_discovery.html for more information.
    changed: [192.168.100.31] => changed=true
      ansible_facts:
        discovered_interpreter_python: /usr/bin/python
      msg: '{u''Status'': u''Success'', u''CLI Command executed'': u''show network
    '', u''IAP IP address'': u''192.168.100.31'', u''Command output'': u''cli output:
    COMMAND=show network
    \r
    Networks
    Profile Name  ESSID             Clients  Type      Band  Authentication Method  Key Management  IP Assignment  Status   Zone  Coding   Active  Max IPv4 Users
    SetMeUp       SetMeUp-C1:AE:C5  0        employee  2.4   None                   none            NAT Mode       Enabled  -     Default  Yes     N/A'', u''Status-code'': 0}'
      status_code: 200
    my playbook looks like this.
    - name: Show existing network
      hosts: aruba_ap315
      connection: local
      gather_facts: no
      tasks:
        - name: Show existing network as a show command through API
          arubainstant_config:
            host: 192.168.100.31
            username: admin
            password: admin
            method: GET
            iap_ip_addr: 192.168.100.31
            api_type: monitoring
            api_name: show network
    what i wan to have is:
    show network
    Networks
    Tried to use a register variable and output.stdout it but register is not supported by this module .
    Regards Markus
  • 2.  RE: Ansible and output of arubainstant_config
    MVP GURU
    Posted Apr 24, 2020 10:14 AM
    Hi Markus,
    What do you need to make ? because ansible is not specific make for display stuff...
  • 3.  RE: Ansible and output of arubainstant_config
    Posted Apr 27, 2020 01:41 AM
    Hi
    I think if I can send show commands to a AP via API it is worth to see the Output readable like on the CLI.
    who needs powershell if you have a nice Bash
  • 4.  RE: Ansible and output of arubainstant_config
    Posted Apr 28, 2020 07:09 PM
    You can use:  | sed 's/\
    /g'
    with ansible-playbook command to get an output similar to what you are looking for.
    Eg: ansible-plabook filename.yml -v | sed 's/\
    /g'
