Developer
Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
This thread has been viewed 28 times
  • 1.  Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
    Posted Dec 14, 2023 05:42 AM
    Hi Community,
    I try to add tagged vlans to uplink ports with an ansible playbook in a loop. During the loop lots of ports get tagged correctly but some fail with "Request failed: <urlopen error _ssl.c:975: The handshake operation timed out>". I use Aruba 2540 with aos YC.16.10.0019
    My playbook looks like this;
    - name: Setup Uplink ports
      hosts: all
      gather_facts: false
      tasks:
        - name: Add tagged vlan to port
          arubanetworks.aos_switch.arubaoss_vlan:
            vlan_id: "{{ item[0].vlan_id }}"
            config: create
            command: config_vlan_port
            port_id: "{{ item[1] }}"
            port_mode: "POM_TAGGED_STATIC"
            use_ssl: true
            port: 443
            query_max_response_time: 20
            robustness: 3
          with_nested:
            - "{{ vlan_configs }}"
            - "{{ uplink_ports }}"
          when:
            - vlan_configs is defined
            - uplink_ports is defined
    vlan_configs looks like this:
    vlan_configs:
      - vlan_id: 1004
        vlan_name: toazz
      - vlan_id: 7
        vlan_name: tawm
      - vlan_id: 11
        vlan_name: takl
      - vlan_id: 12
        vlan_name: tavi
    uplink_ports looks like this:
    uplink_ports:
      - 49
      - 50
      - 51
      - 52
    any help would be nice.
    Cheers
    Christopher
  • 2.  RE: Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
    MVP GURU
    Posted Dec 14, 2023 05:58 AM
    What the configuration of your switch ? for web management ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
    Posted Dec 14, 2023 06:50 AM
    Hi alaoutte,
    no sure what you are asking for. On the switches I configured:
    no web-management
    web-management ssl
    Cheers
    Christopher
  • 4.  RE: Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
    MVP GURU
    Posted Dec 14, 2023 08:04 AM
    you have generate a certificate on the switch ?
  • 5.  RE: Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
    Posted Dec 14, 2023 08:49 AM
    yes, I did. During the loop lots of ports get tagged correctly and communication with the switches works fine, but some fail with this error.
    Cheers
    Christopher
  • 6.  RE: Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
    MVP GURU
    Posted Dec 14, 2023 08:59 AM
    do you have try with http ?t ?
    Do you have try to debug rest ?
  • 7.  RE: Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
    Posted Jan 02, 2024 04:49 PM
    Are any of the interfaces you're configuring ones you're using for the REST API connection as well? Is the VLAN L3 with an IP that you're using for connection?
    Ti Chiapuzio-Wong (they/them)
    HPE Aruba Networking
  • 8.  RE: Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
    Posted Mar 21, 2024 06:25 AM
    sorry, for the delay. Had some other customers with issues ;-)
    @alagoutte Thanks for the hint. I switched now to http only and it looks fine. seems like the ssl handshake fails because of the number of connections made. Is the ssl-engine of 2540 and 2930 switches to slow? I'd prefer to use ssl instead of plain.
    I have debugged REST, but thats working fine.
    @Tiffany.Chiapuzio-Wong The configuration interface is an svi, so it is not directly involved.
    Cheers
    Christopher
  • 9.  RE: Ansible arubanetworks.aos_switch adding tagged vlan fails with "The handshake operation timed out"
    MVP GURU
    Posted Mar 21, 2024 07:26 AM
    Hi Christopher,
    Thanks for feedback,
    Yes, the SSL engine is slow on 25xx/29xx...
    May be need to add tempo (or check if connection keep alive is supported on this ansible module... @Tiffany.Chiapuzio-Wong
