Developer
ANSIBLE: Connection reset by remote peer (switches) in a "random" manner
  • 1.  ANSIBLE: Connection reset by remote peer (switches) in a "random" manner
    Posted Oct 30, 2023 08:28 AM
    Summary
    When I run a playbook that sends commands on remote switches, sometimes some of the tasks fails on some switches, returning an error message "[Errno 104] Connection reset by peer".
    Some important facts:
    • Im using AWX
    • The playbook is scheduled to run every 10min
    • The same switch that fails on the previous playbook run can succeed on the next playbook run
    • the inventory has aprox. 30 switches, all located in the same subnet
    • sometimes, all the switches succeeds, sometimes, a couple switches fails with this message.
    • no specific switches failing, could be any them
    • Switches: J9773A 2530-24G-PoEP (YA.16.10.0015)
    Issue Type
    Bug Report
    Component Name
    arubanetworks.aos_switch.arubaoss_command
    Ansible Version
    AWX 21.13.0
    ansible-core: 2.9
    Configuration
    I'm using the default ansible configuration. No parameters were updated.
    OS / Environment
    RHEL 8
    Steps to Reproduce
    I'm putting one of the tasks from the playbook as an example, but it fails in different tasks in a random way, not on a specific task.
    - name: GET SHOW INT BRIEF OUTPUT TO PREVENT FALSE-POSITIVE
      arubanetworks.aos_switch.arubaoss_command:
        commands:
          - "show interface brief"
        wait_for: result[0] contains Status
      register: int_brief_output_prevent
    - name: Print show interface brief output
      debug:
        msg: "{{ int_brief_output_prevent }}"
    Expected Results
      "msg": {
        "changed": false,
        "stdout": [
          "Status and Counters - Port Status\n\n                   | Intrusion                           MDI  Flow\n  Port  Type       | Alert     Enabled Status Mode       Mode Ctrl\n  ----- ---------- + --------- ------- ------ ---------- ---- ----\n  1     100/1000T  | No        Yes     Up     1000FDx    MDI  off \n  2     100/1000T  | No        Yes     Up     10HDx      MDI  off \n  3     100/1000T  | Yes       Yes     Up     10HDx      MDI  off \n  4     100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  5     100/1000T  | No        Yes     Down   1000FDx    MDIX off \n  6     100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  7     100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  8     100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  9     100/1000T  | No        Yes     Up     10HDx      MDI  off \n  10    100/1000T  | No        Yes     Up     10HDx      MDI  off \n  11    100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  12    100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  13    100/1000T  | No        Yes     Up     100FDx     MDIX off \n  14    100/1000T  | No        Yes     Down   1000FDx    MDIX off \n  15    100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  16    100/1000T  | No        Yes     Up     10HDx      MDIX off \n  17    100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  18    100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  19    100/1000T  | No        Yes     Down   1000FDx    MDIX off \n  20    100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  21    100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  22    100/1000T  | No        Yes     Down   1000FDx    MDIX off \n  23    100/1000T  | No        Yes     Down   1000FDx    MDI  off \n  24    100/1000T  | No        Yes     Down   1000FDx    MDIX off \n  25    1000LX     | No        Yes     Up     1000FDx    NA   off \n  26               | No        Yes     Down   .               off \n  27               | No        Yes     Down   .               off \n  28               | No        Yes     Down   .               off"
        "stdout_lines": [
            "Status and Counters - Port Status",
            "                   | Intrusion                           MDI  Flow",
            "  Port  Type       | Alert     Enabled Status Mode       Mode Ctrl",
            "  1     100/1000T  | No        Yes     Up     1000FDx    MDI  off ",
            "  2     100/1000T  | No        Yes     Up     10HDx      MDI  off ",
            "  3     100/1000T  | Yes       Yes     Up     10HDx      MDI  off ",
            "  4     100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  5     100/1000T  | No        Yes     Down   1000FDx    MDIX off ",
            "  6     100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  7     100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  8     100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  9     100/1000T  | No        Yes     Up     10HDx      MDI  off ",
            "  10    100/1000T  | No        Yes     Up     10HDx      MDI  off ",
            "  11    100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  12    100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  13    100/1000T  | No        Yes     Up     100FDx     MDIX off ",
            "  14    100/1000T  | No        Yes     Down   1000FDx    MDIX off ",
            "  15    100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  16    100/1000T  | No        Yes     Up     10HDx      MDIX off ",
            "  17    100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  18    100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  19    100/1000T  | No        Yes     Down   1000FDx    MDIX off ",
            "  20    100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  21    100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  22    100/1000T  | No        Yes     Down   1000FDx    MDIX off ",
            "  23    100/1000T  | No        Yes     Down   1000FDx    MDI  off ",
            "  24    100/1000T  | No        Yes     Down   1000FDx    MDIX off ",
            "  25    1000LX     | No        Yes     Up     1000FDx    NA   off ",
            "  26               | No        Yes     Down   .               off ",
            "  27               | No        Yes     Down   .               off ",
            "  28               | No        Yes     Down   .               off"
        "ansible_facts": {
          "discovered_interpreter_python": "/usr/bin/python"
        "deprecations": [
            "msg": "Distribution rhel 8.7 on host SW-MAG040-ASW04-R02-ADM should use /usr/libexec/platform-python, but is using /usr/bin/python for backward compatibility with prior Ansible releases. A future Ansible release will default to using the discovered platform python for this host. See https://docs.ansible.com/ansible/2.9/reference_appendices/interpreter_discovery.html for more information",
            "version": "2.12"
        "failed": false
      "_ansible_verbose_always": true,
      "_ansible_no_log": false,
      "changed": false
    Actual Results
      "msg": "Traceback (most recent call last):\n  File \"/usr/local/lib/python3.9/site-packages/ansible/module_utils/connection.py\", line 200, in send\n    response = recv_data(sf)\n  File \"/usr/local/lib/python3.9/site-packages/ansible/module_utils/connection.py\", line 76, in recv_data\n    d = s.recv(header_len - len(data))\nConnectionResetError: [Errno 104] Connection reset by peer\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n  File \"/usr/local/bin/ansible-connection\", line 310, in main\n    conn.set_options(var_options=variables)\n  File \"/usr/local/lib/python3.9/site-packages/ansible/module_utils/connection.py\", line 184, in __rpc__\n    response = self._exec_jsonrpc(name, *args, **kwargs)\n  File \"/usr/local/lib/python3.9/site-packages/ansible/module_utils/connection.py\", line 150, in _exec_jsonrpc\n    out = self.send(data)\n  File \"/usr/local/lib/python3.9/site-packages/ansible/module_utils/connection.py\", line 204, in send\n    raise ConnectionError('unable to connect to socket', err=to_text(e, errors='surrogate_then_replace'), exception=traceback.format_exc())\nansible.module_utils.connection.ConnectionError: unable to connect to socket\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n  File \"/usr/local/bin/ansible-connection\", line 350, in <module>\n    main()\n  File \"/usr/local/bin/ansible-connection\", line 313, in main\n    raise ConnectionError('Unable to decode JSON from response set_options. See the debug log for more information.')\nansible.module_utils.connection.ConnectionError: Unable to decode JSON from response set_options. See the debug log for more information.\n",
  • 2.  RE: ANSIBLE: Connection reset by remote peer (switches) in a "random" manner
    Posted Nov 01, 2023 12:51 PM
    Hi @lhcunha!
    Since this is happening inconsistently it's a little difficult to troubleshoot but we can attempt a few things to try and improve the behavior:
    1) What version of the ansible.netcommon collection do you have installed? This is a dependency for the aos-switch collection and updating it could improve the behavior.
    2) Would you be willing to upgrade your ansible-core version? I believe 2.13 is the most recent
    3) Could you include an ansible.cfg file within your playbook directory that defines host_key_checking = false? This is described here: https://github.com/aruba/aos-switch-ansible-collection#sshcli-modules
    Ti Chiapuzio-Wong (they/them)
    HPE Aruba Networking
  • 3.  RE: ANSIBLE: Connection reset by remote peer (switches) in a "random" manner
    Posted Nov 07, 2023 09:32 AM
    Hi Tiffany, thanks for the answer.
    1) Its ansible.netcommon latest version
    2) I'm not able to update ansible core at this moment
    3) I will do this and update this thread later with the result
