Developer
last person joined: 10 hours ago
Ansible modules for clearpass
  • 1.  Ansible modules for clearpass
    Posted Jun 09, 2021 12:22 PM
    Hi Team,
    Please let me know if there are any new Ansible modules for clearpass tacacs. I see existing modules (like aruba/aruba-ansible-modules) are depreciated and not able to find modules related to clearpass in Aruba Ansible galaxy.
    Still I tried installing the old modules through git hub and getting the below error. I use Ansible 4 and i am not sure if that has something to do with this
    ljeevana@ljeevana-mn1 aruba-ansible-modules % sudo python3 aruba_module_installer/aruba_module_installer.py
    Password:
    There was an issue finding your ansible version.
    Please run 'ansible --version' from bash, resolve any errors, and verify version is release version 2.5 or later.
    ljeevana@ljeevana-mn1 aruba-ansible-modules % ansible --version
    ansible [core 2.11.1]
    config file = None
    configured module search path = ['/Users/ljeevana/.ansible/plugins/modules', '/usr/share/ansible/plugins/modules']
    ansible python module location = /Users/ljeevana/Library/Python/3.8/lib/python/site-packages/ansible
    ansible collection location = /Users/ljeevana/.ansible/collections:/usr/share/ansible/collections
    executable location = /usr/local/bin/ansible
    python version = 3.8.2 (default, Apr 8 2021, 23:19:18) [Clang 12.0.5 (clang-1205.0.22.9)]
    jinja version = 3.0.1
    libyaml = True
    Regards
    Lukesh
    Lukesh Jeevanandam
  • 2.  RE: Ansible modules for clearpass
    MVP GURU
    Posted Jun 09, 2021 04:21 PM
    The error is not very clear...
    What feature do you need ?
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Ansible modules for clearpass
    Posted Jun 10, 2021 02:33 AM
    Thanks, Alex, for the response. Like PowerArubaCP, what is the Ansible module for Clearpass as I see existing modules are depreciated and not able to find the same in Aruba Ansible Galaxy
    Also please ignore about the error as it is not needed anymore.
    Regards
    Lukesh
  • 4.  RE: Ansible modules for clearpass
    MVP GURU
    Posted Jun 10, 2021 05:04 AM
    Do you have try a older release of Ansible ? (2.8 or 2.9)
    (Why don't use PowerArubaCP ;*)
  • 5.  RE: Ansible modules for clearpass
    Posted Jun 10, 2021 05:26 AM
    Hi Alex,
    I have ansible 4.0.0. I am not able to see clearpass related modules in Aruba collection. Which Ansible module I should be using for clearpass related operations
    Regards
    Lukesh
