Developer
Ansible playbook special characters in password
  • 1.  Ansible playbook special characters in password
    Posted 25 days ago
    I can configure the switch via ssh and rest api using the following options in my hosts file:
    10.0.232.254 ansible_network_os=arubanetworks.aos_switch.arubaoss ansible_connection=local ansible_user=admin
    I start the playbook with the following parameters and ask for the password:
    ANSIBLE_NETWORK_GROUP_MODULES=arubaoss ansible-playbook conf_vlan.yml -i hosts.txt --ask-pass
    normal passwords without special characters work just fine.
    when I use a password that includes special characters I get the following error:
    TASK [Create Vlan] *******************************************************************************************************************************************
    failed: [10.0.232.254] (item={'vlanid': '1000', 'vlanname': 'INT-Clients_1'}) => {"ansible_loop_var": "item", "body": "{\"message\":\"Authentication failed.\"}", "changed": false, "connection": "close", "content-type": "application/json", "item": {"vlanid": "1000", "vlanname": "INT-Clients_1"}, "msg": "HTTP Error 400: Bad Request", "requestid": "", "server": "eHTTP v2.0", "status": 400, "transfer-encoding": "chunked", "url": "http://10.0.232.254:80/rest/v6.0/login-sessions"}
    When I connect with ssh or the webui with the special character password there is no problem at all.
    If something is wrong or stupid, please enlighten me.
    Best Regards
    Marc
  • 2.  RE: Ansible playbook special characters in password
    MVP GURU
    Posted 25 days ago
    Hi Marc,
    What the special character do you are using ?
    What the switch model / firmware ?
    May be also report the issue on github repo issue
    https://github.com/aruba/aos-switch-ansible-collection/issues
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Ansible playbook special characters in password
    Posted 25 days ago
    it is because of \.
    I tried: to escape \, $, ', and ", use a double quotation mark around the password or use the back slash (\) as the escape character.
    But that doesn't seem to work.
    HPE Aruba 2930M 48G PoE+ Switch (JL322A)
    Image             Size (bytes) Date     Version
    Primary Image    :    30252184 05/17/23 WC.16.11.0012
  • 4.  RE: Ansible playbook special characters in password
    Posted 25 days ago
    Hi @Soenke Knipp I'll take a look and see if I can reproduce this & find a cause/solution - thank you for your patience as we investigate!
    Ti Chiapuzio-Wong (they/them)
    HPE Aruba Networking
