Developer
Ansible Reboot Playbook
This thread has been viewed 42 times
  • 1.  Ansible Reboot Playbook
    Posted Nov 29, 2022 08:18 PM
    Hi there,  I am wondering if there is other playbook that could reboot an Aruba switch and wait for it to be alive or any one that could advise what did I miss on this playbook so that it will wait for the switch to be up and running. The second task did not execute at all after reboot task. Hope someone could share their experience on this.
    ## Reboot Switch
    - hosts: aoscx_6300
      roles:
        - role: arubanetworks.aoscx_role
      gather_facts: false
      vars:
        ansible_connection: network_cli
        ansible_network_os: aoscx
        ansible_python_interpreter: /usr/bin/python3
        ansible_command_timeout: 240
      tasks:
        - name: reboot device
          aoscx_command:
            commands:
              - command: 'boot system'
                prompt:
                  - '.*\(y\/n\)\?.*'
                answer:
                  -  y
        - name: Execute show version command
          aoscx_command:
           commands: ['show version']
          register: show_version_output
        - name: Output registered variable
          debug:
            var: show_version_output
    Thank you.
  • 2.  RE: Ansible Reboot Playbook
    Posted Nov 30, 2022 03:27 AM
    I have tried a lot of different things, but the only thing that works well is to have Ansible wait a while before continuing.
       - name: Wait for 10 minutes for switch to boot
          wait_for:
            timeout: 600
          delegate_to: localhost
    If anyone has a better solution, I am very interested as well.
  • 3.  RE: Ansible Reboot Playbook
    Posted Nov 30, 2022 03:32 AM
    In regards to your reboot command, you can also use firmware boot module instead of using the command module:
        - name: Boot to {{ boot_partition }}
          aoscx_boot_firmware:
            partition_name: '{{ boot_partition }}'
    or without variable:
    - name: Boot to primary
        partition_name: primary
    - name: Boot to secondary
        partition_name: secondary​
  • 4.  RE: Ansible Reboot Playbook
    Posted Dec 01, 2022 11:55 AM
    Hi @sudovim ! @jonlar is correct and we have an example of that workflow on our aoscx-ansible-workflows repository! Here's a snippet of the check_firmware_then_upgrade.yml playbook that does just that:
    - name: Boot the switch with the new image uploaded to primary partition.
    	partition_name: 'primary'
    - name: Wait for the switch to come online after FW upgrade and reboot.
      wait_for:
    	host: "{{ ansible_host }}"
    	port: 22
    	sleep: 10
    	timeout: 900​
  • 5.  RE: Ansible Reboot Playbook
    Posted Dec 02, 2022 04:05 AM
    Thanks for the reply :) I did try the following the other day on a 6200 stack, but it completed immediately. I will test with port 22 instead.
        - name: Wait for the switch to come online after reboot.
          ansible.builtin.wait_for:
            port: 443
            sleep: 30
            timeout: 600​
  • 6.  RE: Ansible Reboot Playbook
    Posted Dec 02, 2022 02:10 PM
    When working with a stack you'll want to use the "show vsf" command to check the members of the stack instead of the connection of the IP address. You should still validate the IP is reachable but then use SSH commands to validate all the members are up. Here's an example in our AOS-CX Ansible Workflows repo:
    - name: Wait for Standby to join stack by entering Show vsf
      aoscx_command:
    	commands:
    	  - 'show vsf'
    	wait_for:
    	  - result[0] contains "Standby"
    	  #- result[0] contains "Member"
    	match: all
    	retries: 20
    	interval: 5
  • 7.  RE: Ansible Reboot Playbook
    Posted Dec 02, 2022 09:23 PM
    Hi KS9,
    So are you saying that I should use the boot partition module to reboot the switch at the same time wait for the switch to be alive even if I don't really intend to change the boot partition? And there is no other way to achieve that except using @jonlar method. Correct me if I'm wrong.
    Update:
    I tried this exact method and the task completes immediately. It didn't wait for switch to actually come alive.
    Thank you
  • 8.  RE: Ansible Reboot Playbook
    Posted Dec 04, 2022 02:26 AM
    Update Again:
    I think I found the quick fix, by suppressing that failed task. Since the task is rebooting the device and somehow, ansible is "kind of stuck in the reboot task", suppressing the error on "reboot task" will allow subsequent playbooks to proceed as normal showing system uptime.
        - name: Reboot switch
          aoscx_command:
             commands:
                    prompt:
                        - '.*\(y\/n\)\?.*'
                    answer:
                        -  y
           ignore_errors: True
    PS.
    I set the command_timeout to 300 seconds.
    I am still hoping for a much better approach to this.
  • 9.  RE: Ansible Reboot Playbook
    Posted Dec 05, 2022 01:20 PM
    Hi @sudovim - Yes use aoscx_boot_firmware to reboot the switch using REST API - then the wait_for task to ensure the IP is reachable, then the "show vsf" command to verify the rest of the stack is up. The entire playbook could look like the following:
    - name: Reboot switch & verify it's online
      hosts: all
      collections:
        - arubanetworks.aoscx
      tasks:
            #partition_name: 'secondary'
            # Decide which partition should be booted
          wait_for:
            port: 22
            sleep: 10
            timeout: 900
    - name: Verify stack is rebooted
      hosts: all
      collections:
      gather_facts: False
      vars:
      tasks:
          aoscx_command:
            commands:
              - 'show vsf'
            wait_for:
            match: all
            retries: 20
            interval: 5
