ANT-2x2-2005 mounting kits?
  • 1.  ANT-2x2-2005 mounting kits?
    MVP
    Posted Nov 18, 2011 05:17 AM
    According to the .pdf the ANT-2x2-2005 has a pole mounting kit included. Is there any info on how to mount these antenna's to the ceiling or wall or will I have to mount a pole to the ceiling/wall first? :)
    Secondly.. I understand correct this reference is a kit containing 2 seperate antenna's so I'll need 2 mountingkits?
  • 2.  RE: ANT-2x2-2005 mounting kits?
    Posted Nov 18, 2011 09:30 AM
    You can just screw them to the AP: one on the top and one on the bottom lead of radio1.  Would that not work, or you need to mount them to the ceiling?
    It is a package of two antennas.  I am attaching what is on the support website about that antenna.
    Attachment(s)
  • 3.  RE: ANT-2x2-2005 mounting kits?
    MVP
    Posted Nov 21, 2011 04:25 AM
    Its for use in an underground carpark, so we have the choice of either mounting everything to the very solid armored concrete supports which would block a lot of signal to certain area's OR mounting the antenna's from the ceiling with no room to stick the AP inbetween.
    Anyway, with a bit of creativity mounting issues should always be solvable so we'll see what works best.
