  • 1.  ANT-2x2-5314
    Posted May 17, 2016 10:44 PM
    I'm trying to find out if the mounting hardware for the 5314 can be purchased seperately or if there's a compatible mounting kit.  Apprecaite any help!
  • 2.  RE: ANT-2x2-5314
    Posted May 18, 2016 03:12 AM
    From the datasheets:
    http://www.arubanetworks.com/pdf/products/DS_ANT-2x2-5314.pdf
    http://www.arubanetworks.com/pdf/products/DS_ANT-2x2-2314.pdf
    Connectors
    • N-type female x2 (RF cables not included)
    INSTALLATION HARDWARE
    • Mount kit for wall and pole included
    Please work with your partner or local HPE Aruba sales team to create the correct bill-of-materials.
  • 3.  RE: ANT-2x2-5314
    Posted May 18, 2016 11:11 AM
    Sorry if I wasn't clear in my original post, but that isn't what I'm looking for.
    I have several ANT-2x2-5314 that are installed. The mounts were damaged by falling debris, but the antennas themselves are fine. I need to know if the mounts can be purchased separately and if so what is the part?
    This is for a non-profit organization with very little money. They aren't going to want to purchase a $300+ antenna just to get a mount.
    I'm waiting on a reply from our partner, but thought someone in the community might know the answer.
  • 4.  RE: ANT-2x2-5314
    Posted May 18, 2016 11:34 AM
    I just checked the 5314 and the MNT-1 and MNT-3 kits that can be ordered separately, and those will NOT fit..You might find compatible mounts in a local antenna store, or find someone who can make something compatible.
    If you say the mount was damaged, you might be able to use some parts of it still. It surprises me that it was damaged as it seems pretty strong iron parts.. Sorry I cannot help you further.
  • 5.  RE: ANT-2x2-5314
    Posted May 23, 2016 07:23 AM
    Op, I will find out a part number and post to this later today.
  • 6.  RE: ANT-2x2-5314
    Posted May 23, 2016 05:39 PM
  • 7.  RE: ANT-2x2-5314
    Posted May 23, 2016 06:44 PM
    Super helpful! Thanks a ton.
