Wired Intelligent Edge
Any ideas for delaying port-access auth on AOS-CX after power failure?
This thread has been viewed 31 times
  • 1.  Any ideas for delaying port-access auth on AOS-CX after power failure?
    Posted Jul 22, 2021 05:38 AM
    I've run into what I think is a timing issue after a general campus power failure.  We have access switches that are coming online and supplying PoE before the aggregation switch is online and forwarding traffic, causing RADIUS MAC auth to fail on some devices (because the RADIUS server is unreachable).  We're going to try extending the RADIUS timeouts and retries in attempt to add more wiggle room for the slow aggregation switch, but I was curious if anyone here has run into that problem and knows of a different way to solve it.  FYI, not all of the devices we need to MAC auth do LLDP; I've considered LLDP groups as an alternative.
    Daniel Waites
    Sabyr Consulting
  • 2.  RE: Any ideas for delaying port-access auth on AOS-CX after power failure?
    Posted Jul 22, 2021 08:27 AM
    Maybe you have Quick PoE turned on. You didn't say which CX platform.  This expedites the process for end points. To give you wiggle room maybe look int this tuned off if your cores /upstream keep on losing power. But a site failure like this need to look into more holistic issues
    Kamal Takodra
  • 3.  RE: Any ideas for delaying port-access auth on AOS-CX after power failure?
    Posted Jul 26, 2021 10:30 AM
    Sure, this is a 6300.  Quick PoE is not turned on, however we are using the concurrent onboarding feature of the newer software images that does MAC authentication concurrently with EAP, which causes headless devices to come up much faster than would ordinarily be the case.  Because the feature is new, it's likely that most others have not run into this issue yet.  Our test with increased RADIUS retries/timeouts was successful, but this is a potential downside to faster headless onboarding.
    Daniel Waites
  • 4.  RE: Any ideas for delaying port-access auth on AOS-CX after power failure?
    Posted Jul 29, 2021 03:53 AM
    I think maybe I had a similar issue with a customer when using MAC authentication. The access port was coming online much faster than the RADIUS server was becoming reachable. For this reason the MAC authentication was failing and the switch was actually doing by default only 1 attempt to validate the MAC address with the RADIUS server. If this first attempt failed, the switch was not trying again even when the RADIUS server was reachable again, the port remaining in status "failed authentication".
    I concentrated on how to make the switch do a new authentication attempt after a while. This can be done using reauthentication with a short reauthentication period. Configuring reauthentication in the mac-auth context like this
    switch(config-if)#aaa authentication port-access mac-auth
    switch(config-if-macauth)#reauth
    switch(config-if-macauth)#reauth-period 65
    is not feasible because it will happen continuously after successful authentication and overwhelm the RADIUS server with requests.
    It is better to use the critical-role feature. The critical-role is applied when the authentication fails because RADIUS server is not reachable. You can configure a short reauthentication period in the critical role and maybe some void VLAN. When the MAC authentication fails the switch will not block the client completely but place it in the critical-role where it has no network access and reauthentication is enforced in some short intervals. Eventually the RADIUS server will come online and one of the subsequent reauthentication attempts will succeed which will place the user in the right role with the correct settings and possible no reauthentication or reauthentication with a more reasonable period.
    This is the config I used in the test.
    interface 1/1/1
        shutdown
        downshift-enable
        qos trust dscp
        no routing
        vlan access 1
        spanning-tree port-type admin-edge
        aaa authentication port-access allow-cdp-bpdu
        aaa authentication port-access client-limit 10
        aaa authentication port-access critical-role TEST
        port-access allow-flood-traffic enable
        aaa authentication port-access dot1x authenticator
            eapol-timeout 2
            max-eapol-requests 2
            max-retries 1
            enable
            enable
    port-access role TEST
        reauth-period 40
    This is what worked for this customer, not sure how helpful it can be for you.
    Emil Gogushev
  • 5.  RE: Any ideas for delaying port-access auth on AOS-CX after power failure?
    Posted Jul 29, 2021 09:56 AM
    Ah, this is a really good idea!  I actually did something similar to this for the fall-through role in MAB (the group that gets assigned if no other matches).  I just didn't think to do this for the critical role.
    Thanks!
    Daniel Waites
    Senior Cloud Infrastructure Engineer
    Sabyr Consulting
    www.sabyr.com
    (409) 206-0827 - office
    (409) 454-7250 - cell
