any known issues connecting older AP124s with 3.3.2.14 flash to controllers running 6.1 or 6.2?
  • 1.  any known issues connecting older AP124s with 3.3.2.14 flash to controllers running 6.1 or 6.2?
    Posted Oct 11, 2013 12:28 PM
    Randy
  • 2.  RE: any known issues connecting older AP124s with 3.3.2.14 flash to controllers running 6.1 or 6.2?
    Posted Oct 11, 2013 01:32 PM
    Yes...  You need to upgrade it to the latest ArubaOS 5.x first.  The problem is tha 3.x images have a hard limit on an upgrade image size..  ArubaOS 6.x exceeds that limit, but 5.x is needed so that the AP can upgrade AND change that limit.  So you need to first connect those access points to a controller that is running the latest 5.x, then go to 6.x
