Any known issues with Aruba and Windows NPS ?
  • 1.  Any known issues with Aruba and Windows NPS ?
    Posted Feb 04, 2013 12:30 PM
    From time to time I have a few clients that can't connect to my wireless network.   Out of 150 clients per day, I woud say that I hear of five or siz people per week that have problems connecting.  All have up-to-date drivers and the types of users and laptops  vary.  If I could pinpoint anything, I'd say it tends to happen more when a user goes from being docked on the wired network to being on wireless as they move to a meeting room.
    It is proving very difficult to nail down, but I believe it has something to do with how the Aruba controllers is talking to my Windows RADIUS servers.   On one particular occasion, I had a client which wouldn't connect, even without a reboot.  So I switched the RADIUS server order around in my RADIUS server group, and the client connected right away.
    I setup client debugging and what I see is that the client associates, but then times out and deauths itself.   A sh auth-tracebuf shows the EAP exchange start, but after the controller sends an EAP-REQ, it receives no response from the client.
    I noticed the following statistics on the controller in regards to RADIUS , and it has high timeouts as well as showing the RADIUS. servers up for only a short amount of time.
    One of the RADIUS servers is on the same LAN as the controller, the other is in the US accessed via a WAN link.
    I've had the Windows guys log everything, but they can't seem to find anything wrong.
    Here's some output, I would appreciate any help with trying to work this out.   We are running AOS6.1.3.3
    RADIUS Server Statistics
    Statistics             ukradius0  usradius3
    Accounting Requests    12621     16170
    Raw Requests           203134    233577
    PAP Requests           0         0
    CHAP Requests          0         0
    MS-CHAP Requests       0         0
    MS-CHAPv2 Requests     0         0
    Mismatch Response      7         2
    Bad Authenticator      0         0
    Access-Accept          12837     13920
    Access-Reject          798       811
    Accounting-Response    12621     16170
    Access-Challenge       188658    217231
    Unknown Response code  0         0
    Timeouts               3378      6505
    AvgRespTime (ms)       11        115
    Total Requests         215755    249747
    Total Responses        214921    248134
    Uptime (d:h:m)         0:0:5     0:1:39
    SEQ Total/Free         255/255   255/255
    #AP115
  • 2.  RE: Any known issues with Aruba and Windows NPS ?
    MVP
    Posted Feb 04, 2013 02:21 PM
    What does your aaa authentication dot1x profile look like? We successfully used Microsoft NPS before we moved to ClearPass Policy Manager as our RADIUS server.
    Aruba has not chosen reasonable default values in the dot1x authentication profile.
    Here is our current dot1x authentication profile.
    aaa authentication dot1x <insert your name here>
    machine-authentication machine-default-role "denyall-role"
    machine-authentication user-default-role "denyall-role"
    timer idrequest_period 5
    timer quiet-period 3
    server server-retry-period 5
    server server-retry 3
    max-requests 5
    timer wpa-key-period 2000
    timer wpa2-key-delay 100
    timer wpa-groupkey-delay 100
    wpa-key-retries 2
    validate-pmkid
    Bruce Osborne
    Liberty University
  • 3.  RE: Any known issues with Aruba and Windows NPS ?
    Posted Feb 04, 2013 05:18 PM
    HI Bruce,
    Here is our current profile, it looks a bit different to yours, any particular settings that you'd recommend we change ?
    802.1X Authentication Profile "global-802.1x-default-auth-profile"
    Parameter                                                  Value
    Max authentication failures                                0
    Enforce Machine Authentication                             Disabled
    Machine Authentication: Default Machine Role               guest
    Machine Authentication Cache Timeout                       24 hr(s)
    Blacklist on Machine Authentication Failure                Disabled
    Machine Authentication: Default User Role                  guest
    Interval between Identity Requests                         30 sec
    Quiet Period after Failed Authentication                   30 sec
    Reauthentication Interval                                  86400 sec
    Use Server provided Reauthentication Interval              Disabled
    Multicast Key Rotation Time Interval                       1800 sec
    Unicast Key Rotation Time Interval                         900 sec
    Authentication Server Retry Interval                       30 sec
    Authentication Server Retry Count                          2
    Framed MTU                                                 1100 bytes
    Number of times ID-Requests are retried                    3
    Maximum Number of Reauthentication Attempts                3
    Maximum number of times Held State can be bypassed         0
    Dynamic WEP Key Message Retry Count                        1
    Dynamic WEP Key Size                                       128 bits
    Interval between WPA/WPA2 Key Messages                     1000 msec
    Delay between EAP-Success and WPA2 Unicast Key Exchange    0 msec
    Delay between WPA/WPA2 Unicast Key and Group Key Exchange  0 msec
    Time interval after which the PMKSA will be deleted        8 hr(s)
    WPA/WPA2 Key Message Retry Count                           3
    Multicast Key Rotation                                     Disabled
    Unicast Key Rotation                                       Disabled
    Reauthentication                                           Disabled
    Opportunistic Key Caching                                  Enabled
    Validate PMKID                                             Disabled
    Use Session Key                                            Disabled
    Use Static Key                                             Disabled
    xSec MTU                                                   1300 bytes
    Termination                                                Disabled
    Termination EAP-Type                                       N/A
    Termination Inner EAP-Type                                 N/A
    Token Caching                                              Disabled
    Token Caching Period                                       24 hr(s)
    CA-Certificate                                             N/A
    Server-Certificate                                         N/A
    TLS Guest Access                                           Disabled
    TLS Guest Role                                             guest
    Ignore EAPOL-START after authentication                    Disabled
    Handle EAPOL-Logoff                                        Disabled
    Ignore EAP ID during negotiation.                          Disabled
    WPA-Fast-Handover                                          Disabled
    Disable rekey and reauthentication for clients on call     Disabled
    Check certificate common name against AAA server           Enabled
  • 4.  RE: Any known issues with Aruba and Windows NPS ?
    Posted Feb 06, 2013 10:41 PM
    I just wanted to add that my NPS servers show an inaccurate uptime as well.  My servers have been up since the weekend, but my controller shows their uptime is around a few hours.  I have some ClearPass servers, and an ACS server, and their uptime appears to be more accurate.  Wondering if this is a bug.
  • 5.  RE: Any known issues with Aruba and Windows NPS ?
    Posted Feb 11, 2013 03:29 AM
    I saw something similar - if there's many Radius timeouts, do a Wireshark between controller and WAN Radius and look for "ICMP destination unreachable - fragmentation needed"...that would be symptom.
    V.D.
  • 6.  RE: Any known issues with Aruba and Windows NPS ?
    Posted Feb 11, 2013 05:57 PM
    Since making the changes last week, my uptime numbers are improved, but I still show the RADIUS servers as being up for only a few hours before they get marked down again.  It's not a fragmentation issue as the controller and one of the RADIUS servers is on the same VLAN.
    I haven't heard of any users being unable to connect since I made the change but it's not unusual for them not to report this.
    Another point of note,  we also have Cisco autonomous AP's here, which use the same RADIUS servers (we have around 50 RADIUS servers globally) and I checked a few of them today, and they also seem to show a short uptime of a few hours.
    So it seems to me it's not just Aruba related, akthough I'm not aware of any users having issues connecting to our Cisco AP's.
    Anyone got any ideas as to how to troubleshoot this further ?
