Anyone configured AirGroup for Sketch?
  • 1.  Anyone configured AirGroup for Sketch?
    Posted Jun 25, 2014 02:35 PM
    We're trying to use an app called Sketch:
    http://www.bohemiancoding.com/sketch/
    And there's some sort of mirror function that works between the mobile device and the desktop that uses bonjour to find each other, but I can't seem to make AirGroup pass it.  They say the service is _BCBonjour._tcp.local but this config didn't work:
    airgroupservice "Sketch"
      id "_bcbonjour._tcp"
      description "SketchMirror"
    airgroup service "Sketch" enable
  • 2.  RE: Anyone configured AirGroup for Sketch?
    Posted Jun 25, 2014 05:29 PM
    I'm not familiar with Sketch specifically, but I've worked alot with troubleshooting bonjour & Airgroup. Sounds like it's simliar to iOS mirroring. I'm guessing that the two devices are on seperate networks? When you do a "show airgroup users" & "show airgroup servers", do the devices show up with any services at all?
  • 3.  RE: Anyone configured AirGroup for Sketch?
    Posted Jun 25, 2014 06:09 PM
    No, both devices are on the same VLAN.  We just block multicast by default.
  • 4.  RE: Anyone configured AirGroup for Sketch?
    Posted Jun 26, 2014 05:18 PM
    What is the layer 3 device for this network? If its the controller I'm not sure why this wouldn't work. Where are you blocking multicast at? How about the output from the commands? Sketch device showing up with advertised services?
  • 5.  RE: Anyone configured AirGroup for Sketch?
    Posted Jun 26, 2014 08:44 PM
    Based on the twitter exchange here:  https://twitter.com/sketchapp/status/423091799285334016 and the post here:  http://bomberstudios.com/post/54587126654/using-sketch-mirror-liveview-silkscreen-skala it seems like the performance in an enterprise network with alot of devices is not that good, even if you can get it working.  They are suggesting  a USB cable...
