Anyone have the AP315 LED status codes?
This thread has been viewed 38 times
  • 1.  Anyone have the AP315 LED status codes?
    Posted Sep 19, 2016 03:12 PM
    There used to be 4 LEDs on the APs, but I got a 315 and there are only 2 LEDs. Does anyone have the status codes for the 2 LEDs?
    Does it just condense the 5Ghz and 2.4Ghz into a single LED? And remove the Ethernet LED all together?
    That's my best guess but haven't found documentation to support. I have an Amber/Red light on that I'm hoping PoE power save.
    For reference, this is the table I used to use.
  • 2.  RE: Anyone have the AP315 LED status codes?
    Posted Sep 19, 2016 03:33 PM
  • 3.  RE: Anyone have the AP315 LED status codes?
    Posted Apr 06, 2017 04:31 AM
    Hey there,
    I have setup AP-314 with AP-ANT-1W. Function is good but Power LED is RED while Network LED is GREEN.
    How can i get information what System Error condition the AP faces?
  • 4.  RE: Anyone have the AP315 LED status codes?
    Posted Apr 06, 2017 06:34 AM
    You should get the tech support from that AP.
  • 5.  RE: Anyone have the AP315 LED status codes?
    Posted Jul 13, 2017 03:14 PM
    Anybody know what the flashing amber light on the AP-303h means? Can't find any documentation
  • 6.  RE: Anyone have the AP315 LED status codes?
    Posted Jul 13, 2017 03:16 PM
    I found what I was looking for..
