Anyone know the DHCP fingerprint for the Google Glass devices , so I can add it to the role condition (and thus avoid the captive portal)?
if you have a GoogleGlass device to test, you can determine the fingerprint using the procedure in the attached TechNote. Specifically the Identifying a DHCP Fingerprint section: http://www.arubanetworks.com/vrd/AOSDHCPFPAppNote/Chap2.html#1035710
Attachment(s)
DHCP Option55 1,33,3,6,15,28,51,58,59DHCP Option60 dhcpcd-5.2.10:Linux-3.0.31-27935-g01ccedd:armv7l:OMAP4430
Can't get the smiley to stop rendering but that should be 7 l : O M A P
(without the spaces)
Should have known you'd have the specifics Tim! Tim, do you know if this is unique to "Glass" and not any other Google products/devices?
It seems to be. We have about 6 on the network and they all profile the same.
The common OUI seems to be f8:8f:ca and they present a hostname similar to Android phones (android-<randomstring>)
Here's how ClearPass and the controller profiles it. The host user agent fingerprint is via IF-MAP from the controller.
The DHCP fingerprint would be in Hex. For example, an Aple iOS device has a DHCP fingerprint of "370103060F77FC" (see example below):
aaa derivation-rules user byod-rules set role condition dhcp-option equals "370103060F77FC" set-value BYOD-Devices_user-role description "Apple iOS"
The Google Glass device would have its own (hex) DHCP fingerprint ...
