Anyone know where I can find the installation guide for AP-210 series?
  • 1.  Anyone know where I can find the installation guide for AP-210 series?
    Posted Oct 10, 2014 01:49 PM
    Anyone know where I can find the installation guide for AP-210 series?   it doesn't appear to be in the usual place...
  • 2.  RE: Anyone know where I can find the installation guide for AP-210 series?
    Posted Oct 10, 2014 02:16 PM
    Looks like it's been posted in the wrong location but here it is.
    http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14551
    I'll get its posting fixed.
  • 3.  RE: Anyone know where I can find the installation guide for AP-210 series?
    Posted Oct 10, 2014 02:57 PM
    The folder should now appear properly. Sorry for the inconvenience.
  • 4.  RE: Anyone know where I can find the installation guide for AP-210 series?
    Posted Oct 10, 2014 03:06 PM
    In one sense, it does - thanks...   I would though usually browse down through the Navigator on the LHS of the Documentation page:   Expand 'Hardware Installation Guides' then expand  'APs' folder.    If you do that, the folder I expect to see for AP-210 Series doesn't appear.
    If you navigate in a different way - down through Root Collection in the middle of the screen, then 'Hardware Installation Guides'  and  'APs' folder the AP-210 series folder does now appear.   Just depends how you browse...
    Thanks again!
  • 5.  RE: Anyone know where I can find the installation guide for AP-210 series?
    Posted Oct 13, 2014 09:52 PM
    Paul,
    Double check again, I see the folder in the LHS drop down.
    Best regards,
    Madani
  • 6.  RE: Anyone know where I can find the installation guide for AP-210 series?
    Posted Oct 14, 2014 04:25 AM
    It's there now  :)
    Maybe I just needed a 'refresh' on the page...?   Anyway = sorted, thanks!
