Anyone Moved from Meru/Fortinet to Aruba?
  • 1.  Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 11, 2018 08:01 PM
    Wondering if anyone has moved from a Meru/Fortinet wireless infrastructure to Aruba?  We keep having weird issues with clients getting disconnected or not being able to connect sometimes.  Support has not been a whole lot of help honestly.  Every problem we report is a bug that gets referred to engineering, which may or may not eventually release a fix.  Fixed problems frequently come back in later releases.
    We have about 200 HPE/Aruba switches that we are very happy with.  I got a couple of IAP305's to play with and the config is very easy and all the defaults seem sane.  Just wondering if anyone has converted and if so, how would you compare the two?
  • 2.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 11, 2018 08:13 PM
    Are you using the Fortinet "Integration" APs that use the FortiGate as the controller, or the WLC (the former Meru controller) and either Meru or Universal APs? I'm assuming you aren't using the controller-less FortiCloud managed APs.
  • 3.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 11, 2018 08:23 PM
    It's the WLC controllers and non-universal APs. The AP models are 1020, 822, and 832.  Some are marked Meru and some are marked Fortinet, but identical otherwise.
  • 4.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 11, 2018 08:26 PM
    Okay, so definitely the original Meru product. Thanks for the clarification.
    I'll reserve comment since I'm an Aruba employee, but hopefully the clarification will help get a response from a customer/reseller who has experience with both products.
  • 5.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 11, 2018 08:30 PM
    Thanks, and yes I'd prefer non-competitor response.
    I will say that I really like how responsive Aruba is on these forums.  It seems like a great community.
  • 6.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 11, 2018 08:46 PM
    The best community in existence :-p
  • 7.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 12, 2018 09:02 AM
    The company I work install both Meru and Aruba wireless. Aruba is taking over the majory of our new installs but both are solid solutions. The IAP's are great and an easy solution to get up and running quickly, I do tend to stick with the Conservative release of firmware (Current is 6.5.3.6) as I have had some funny issues happen when running the latest Standard firmware (Current is 6.5.4.6). I like all the bugs out of the firmware before updating to it..!!!
    I have a couple of sites running 6.5.3.6 with no issues.
    JD
  • 8.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 12, 2018 02:04 PM
    Thanks for the info.  Did you run vcell or native cell for your Meru installs?  I get conflicting information, depending on who I talk with at support.  We're running vcell for everything right now.
    Any comparisons you can give between the two?
  • 9.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 14, 2018 03:01 PM
    Hi JLester,
    What industry are you in (ex: Higher Education/University) - 802.1x SSID, Guest SSID, BYOD, etc? We transitioned from Meru to Aruba at our university as part of a 3-year campus-wide-redesign initative - and have made several changes as part of that upgrade (some made possible by Aruba). So I was curious about your industry/environment to best formulate my response. :-) I want it to a "fair and accurate response" as some problems we ran into were masked by other problems.
    I was a 2nd Level Help Desk analyst during our transition from Cisco to Meru (short-lived) and then I joined as a Wirless Network Engineer right about time our university decided to move from Meru to Aruba.
  • 10.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 16, 2018 08:22 AM
    We're K-12 education.  We have 17 campuses and around 850 access points currently.  There is basically an AP in every classroom and common areas.  Middle and high schools have 802.11n and elementary have 802.11ac.  We typically see 5500-6000 wireless clients connected each day across the entire district.
  • 11.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 17, 2018 07:46 AM
    Our Meru environment was comprised of 8xMC4200s and AP-320/AP-320i 802.11n Access Points (About 1275 APs) across our university campus. My information is a bit dated as they started to transition to Aruba in 2014 and we were running System Director 6.X. My co-engineers reported a similar situation with "bugs that were resolved also returning in later revisions". They also disabled "Band-Steering" and "Virtual Cell/Port" to improve stability of our controllers and client connectivity. Essentially getting to the point where they needed to disable "special sauce" features. They also reported issues with settings randomly "reverting" for channel/transmit power/gain settings.
    Native Cell vs Virtual Cell/Port
    Note that was 2 major versions ago so I'm unsure if any of that still applies/relevant with Fortinet. Here's some of the things we've done with Aruba.
    • Collapsed our 8 Client VLANs (unique to each Meru Controller) into a Single Flat VLAN for our 802.1x SSID - which has worked well for roaming along with "Drop Broadcast and Unknown Multicast".
    • Self-Guest Sponsorship and Device IoT Registration (Headless/Non-802.1x Devices) registration through Clearpass for students that want to use their Streaming Media TVs, Rokus, Firesticks, Google Home Minis, Alexas, etc.
    • Aruba AirGroup - suppressing/allowing mDNS/SSDP discovery protocols without flooding the network.
    • We're also a big fan of the "User Role" firewall policies that ArubaOS utilizies. Starting to look into placing special-purpose machines into their own VLAN based on AD attributes.
    A couple settings you may want to check on your Meru Controllers
    • 802.1x Network Initiation - A setting that I discovered while troubleshooting the following -  "iPod Touch (6 years old) - 2.4GHz Only - Residence Hall (Hallway AP deployment) - Not working in the residence halls. After taking the time to troubleshoot-evaluate the issue - discovered the device stopped passing traffic after roaming - also "Android Devices" would always prompt to "Join our network". I troubleshooted further - there was a setting on that specific meru controller "8021x Network Initiation" - that had either "reverted" to "disabled" or been changed from the other controllers. Once we changed it to "enabled" - the iPod Touch started working well and Android device properly auto-joined the network. Unsure of what other positive affects this had on other devices.
    • If you're not using it, make sure multicast is disabled. This was a setting I discovered had become re-enabled on our meru controllers and signficantly degraded the wireless in 3 lecture halls. It occured during the beginning of our Aruba re-design and the issue was masked by the fact the these lecture halls either had one AP covering 200 - 500 seats and increase in client density - high channel utilization,etc (naturally there's going to be a problem). But when I saw a twitter post (screen shot of a ticket) had been put in - I took additional time to look into the issue since the student had taken time to put in the ticket - sure enough - found this second problem. Once we corrected the issue - channel utilization decreased - and we saw an additional 2,000 client devices! This is one of the big reasons why when Meru is mentioned to be "awful/terrible" by co-engineers, I'm quick to comment when we isolated this issue - it work decently (minus the band-steering and virtual cell/port technology that were advertised). Also, this another big example on why I take the time to evaluate the variables in our environment instead of jumping to "it's a client device issue" - mostly due to my background as a Help Desk Analyst.
    Tha'ts not to say they didn't have some other stability issues. There was a time where the Meru Controllers crashed every 4 weeks and they had to periodically reboot them. Dual-Uplinks - Port-Channel didn't behave correctly so we had limited redundancy if the distribution uplink failed. There was also some compatibility issues with their chassis. That's all historical information before I joined the wireless team though.
    Hope that helps you a bit.
    Christopher Johnson
    Wireless Network Engineer
  • 12.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Apr 17, 2018 08:04 AM
    Really great information and you mentioned some of the issues we keep having where settings just randomly change.  The last blog you linked to was actuall the person that did our original install.
    We did a test last night by changing one school completely over to native cell and using their ARRP (similar to Aruba's ARM I think).  We also turned on band steering and set everything back to the defaults.  We're going to see how it goes over the next couple of days.
  • 13.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Jun 20, 2019 04:16 PM
    Great info!!!! I might be doing the same move from VCell legacy Meru to Aruba so this definetily helps.
    Question: Were you able to change gradually and have both systems co-exist or did you changed entire campus at a time?
    AP.-
  • 14.  RE: Anyone Moved from Meru/Fortinet to Aruba?
    Posted Jun 21, 2019 06:34 PM
    I wouldn't recommend using both in the same buildings.  We did complete swaps.  There was probably an hour or two where both were up and working, but not much longer than that.  We've been very happy with Aruba.  We haven't touched the settings, just let it do its thing with mostly the defaults.  I've had zero complaints about wireless in the buildings we have swapped and am really looking forward to swapping them all over the next couple of years.
