AOS-CX Switch Simulator
Anyone running MPLS with the simulator?
This thread has been viewed 41 times
  • 1.  Anyone running MPLS with the simulator?
    Posted Apr 10, 2023 11:41 AM
    According to the release notes of the version 10.09, MPLS L3VPN should be supported on the simulator.
    However, I am not able to make it working.
    My testing topology is really simple: 2 PE and 2 CE.
    It seems that the control plane is working perfectly, while the userplane is not.
    Example config for PE1:
    vrf blue
        rd 65000:1
        l3vpn-only
        address-family ipv4 unicast
            route-target export 65000:1
            route-target import 65000:1
        exit-address-family
    interface 1/1/1
        description pe1 -> pe2
        no shutdown
        ip address 10.1.0.1/30
        ipv6 address link-local
        ip ospf 1 area 0.0.0.0
        ip ospf network point-to-point
        mpls enable
        mpls ldp enable
    interface 1/1/2
        description pe1 -> edge1 [external]
        no shutdown
        vrf attach blue
        ip address 10.1.0.6/30
    router ospf 1
        router-id 10.0.0.11
        area 0.0.0.0
    router bgp 65000
        bgp router-id 10.0.0.11
        bgp log-neighbor-changes
        neighbor 10.0.0.12 remote-as 65000
        neighbor 10.0.0.12 description pe2
        neighbor 10.0.0.12 update-source loopback 0
            neighbor 10.0.0.12 activate
            neighbor 10.0.0.12 next-hop-self
            neighbor 10.0.0.12 send-community both
            network 10.0.0.11/32
        exit-address-family
        address-family vpnv4 unicast
            neighbor 10.0.0.12 send-community extended
        exit-address-family
        vrf blue
            neighbor 10.1.0.5 remote-as 65101
            neighbor 10.1.0.5 description edge1
                neighbor 10.1.0.5 activate
                neighbor 10.1.0.5 send-community standard
                redistribute connected
                redistribute local loopback
            exit-address-family
    mpls
        enable
        label-protocol ldp
            enable
            router-id loopback0
    Routing table for VRF blue:
    pe1# show ip route vrf blue
    Displaying ipv4 routes selected for forwarding
    Origin Codes: C - connected, S - static, L - local
                  R - RIP, B - BGP, O - OSPF
    Type Codes:   E - External BGP, I - Internal BGP, V - VPN, EV - EVPN
                  IA - OSPF internal area, E1 - OSPF external type 1
                  E2 - OSPF external type 2
    VRF: blue
    Prefix              Nexthop          Interface     VRF(egress)       Origin/   Distance/    Age
        Type      Metric
    10.0.0.21/32        10.1.0.5         1/1/2         -                 B/E       [20/0]       00h:12m:08s
    10.0.0.22/32        10.0.0.12        -             -                 B/V       [200/0]      00h:12m:03s
    10.1.0.4/30         -                1/1/2         -                 C         [0/0]        -
    10.1.0.6/32         -                1/1/2         -                 L         [0/0]        -
    10.1.0.8/30         10.0.0.12        -             -                 B/V       [200/0]      00h:12m:03s
    100.64.1.0/24       10.1.0.5         1/1/2         -                 B/E       [20/0]       00h:12m:08s
    100.64.2.0/24       10.0.0.12        -             -                 B/V       [200/0]      00h:12m:03s
    Total Route Count : 7
    As you can see, the routes are correctly exchanged (100.64.1.0/24 and 10.0.0.21/32 are originated from CE1, 100.64.2.0/24 and 10.0.0.22/32 are originated from CE2).
    Additionally, all the connected routes are redistributed.
    MPLS bindings seems good as well:
    pe1# show mpls forwarding
    MPLS Bindings
    Entry Bindings   : 1
    Exit Bindings    : 3
    Transit Bindings : 1
    PHP Mode         : Explicit-Null
    QoS Mode         : Uniform
    TTL Propagation  : Uniform
    Entry Bindings:
    Origin   Prefix              Ingress           Nexthop             Outgoing  Egress        Egress            Status
                                 VRF               Address             Label     Interface     VRF
    BGP      -                   blue              10.0.0.12           16        -             default           operational
    Exit Bindings:
    Origin   Prefix              Incoming  Egress            Status
                                 Label     VRF
    BGP      n/a                 16        blue              operational
    system   n/a                 exp-null  default           operational
    system   n/a                 7         default           operational
    Transit Bindings:
    Origin   Prefix              Incoming  Egress        Egress            Nexthop             Outgoing  Status
                                 Label     Interface     VRF               Address             Label
    LDP      10.0.0.12/32        17        1/1/1         default           10.1.0.2            exp-null  operational
    However, if I try a ping from CE1 to CE2, or even a ping from PE1 to PE2 inside the blue vrf, I got a "net unreachable".
    pe1# ping 10.1.0.10 vrf blue source 10.1.0.6
    PING 10.1.0.10 (10.1.0.10) from 10.1.0.6 : 100(128) bytes of data.
    ping4: sendmsg: Network is unreachable
    (if I do a packet tracing, I see the ping arriving from CE1, but never leaving PE1)
    Any idea?
  • 2.  RE: Anyone running MPLS with the simulator?
    Posted Apr 14, 2023 09:48 PM
    I suggest testing it with 10.11.x simulator image. I checked the release notes for it, and it does not mention MPLS in feature caveats. so it should be supported.
  • 3.  RE: Anyone running MPLS with the simulator?
    Posted Apr 15, 2023 03:39 AM
    Sorry I forgot to say that I am already using the latest version.
    Stefano
  • 4.  RE: Anyone running MPLS with the simulator?
    Posted Aug 04, 2023 03:46 AM
    Tried also with 10.12, still not working :-(
  • 5.  RE: Anyone running MPLS with the simulator?
    Posted Dec 15, 2023 12:16 PM
    Im using AOS-CX 10.13, also have the similar issue.
    Although the data plane already got the BGP routing exchanged. The data plan seems not able to install the routing into MPLS forwarding table .
    noted the table the "prefix" and "Egress interface" are missing in the forwarding table :-(
    Don't know any support from Aruba on this simulator...
