You have both the AOS8 and AOS10 deployments in Central?
What happens to the screen you shared if you just show the group/site with the AOS8 or the AOS10? Do both show the same services? And do both show servers and clients?
I don't really see why TAC needs OTA captures, unless they have checked the configuration, list of servers and clients already and don't get a reason why they don't see either of those. You can always ask TAC for an alternative plan if it is infeasible to collect their first choice of datapoints.
Original Message:
Sent: Oct 31, 2022 10:08 AM
Subject: AOS 10 Air Print not working
We are completely Aruba Central and running AOS 10 throughout the majority of our locations with the exception of 3 smaller sites who are still running the 8.x code. Air Print will not work at any of the AOS 10 sites but continues work at the AOS 8 locations. Airplay works and I can see traffic passing at all sites. Is there something I am missing in the configuration or has anyone else experienced the issue? I have an open TAC case but they need me to be on site and taking OTA captures which I am not able to do so until later this week. Any insight would be appreciated.
