Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
AOS 10 PSK SSID failure
This thread has been viewed 41 times
  • 1.  AOS 10 PSK SSID failure
    Posted Jan 25, 2023 09:48 AM
    Hi community,
    I ran into a strange issue with AOS10 (10.3.1.3) and a tunneled PSK SSID. When I connect a client to the SSID it gets the message that the PSK is not correct. At the client page in Central the failure is: MAC Auth failed - but there is no MAC Auth configured on the SSID profile.
    I'm not quite sure if I am doing something wrong (config) or it is a bug.
    Frederik
  • 2.  RE: AOS 10 PSK SSID failure
    Posted Jan 25, 2023 05:32 PM
    i think the next recommended version i.e 10.4 will address this.
  • 3.  RE: AOS 10 PSK SSID failure
    Posted 8 days ago
    Hi, i upgrade my lab form 10.3.1.4 to 10.4.0.0 and the issue persists. Is there any work around? I've opened a TAC case but thought if someone has fixed this they could share here as well .
  • 4.  RE: AOS 10 PSK SSID failure
    Posted Jan 26, 2023 02:44 AM
    side note: PSK Authentication in Bridge Mode is working fine!
    Frederik
  • 5.  RE: AOS 10 PSK SSID failure
    Posted Jan 26, 2023 05:05 AM
    yes that error is only for the tunnel mode
  • 6.  RE: AOS 10 PSK SSID failure
    Posted 6 days ago
    It is possible that there is a misconfiguration or a bug causing the issue with the tunneled PSK SSID on AOS10. Without more information, it is difficult to determine the exact cause of the problem. You may need to review the configuration settings and troubleshoot the issue further to identify the root cause.    home bargains staff portal
  • 7.  RE: AOS 10 PSK SSID failure
    Posted 6 days ago
    I totally agree with you; BUT if the tunneled SSID with PSK authentication is the only configuration which is done (by wizzard), than there isn't much to review.
    Frederik
